Wanted: 3-rib engine repair manual
09-06-2022, 03:15 PM
Does anyone happen to have a 4age engine repair manual PDF for the early 3-rib block? All I can find online are the 87 and later manuals that only refer to the 42mm crank and floating pistons.
I believe it should be covered in the 1983 manual for all A-series blocks, which I cant find anywhere.
09-06-2022, 05:15 PM
I also only have the manual dated 1987 in PDF form. I'm not sure which paper version I have in the shurgard, but if it's an earlier version you can borrow it. I'll check next time I'm there.
[Image: AEU86 AE86 - Wanted: 3-rib engine repair manual]
09-06-2022, 05:26 PM
The Doctor just messaged me, he has the actual 1983 FSM I'm looking for, only paperback, not PDF.
I'll try to scan it if it's not too much hassle at work
Verstuurd vanaf mijn Pixel 4a met Tapatalk
09-06-2022, 09:56 PM (This post was last modified: 09-06-2022 09:57 PM by banpei.)
Maybe you can just scan the pages that are different?
I'll still have a look which version I own. Maybe I can help out with scans as well. Wink
09-07-2022, 06:04 PM
I have a 1986 AE86 paper manual... can make a few scans if you'd like....... likely just jpg
Dan -
09-08-2022, 08:25 AM
If it's relevant to the 40mm crank and perhaps the piston pin replacement procedure, that would be much appreciated Dan.
09-09-2022, 07:46 PM
As far as the wrist pin.... it says use SST. Typically a 1st gen 4AGE requires a rod heater to properly fit the wrist pin.
As far as 40mm crank info:
Main journal diameter: 47.985mm - 48.000mm(1.8892" - 1.8898")
Rod Journal diameter: 39.985mm - 40.000mm(1.5742" = 1.5748")
Maximum runout: .06mm(.0024")
Maximum taper/out of round: .02mm(.0008")
Main journal clearance: .012mm - .039mm(.0005".0015") Limit .10mm(.0039")
Rod journal clearance: 0.020mm - 0.051mm (.0008" - .0020"). limit .08mm(.0031")
Thrust clearance: .02mm - .22mm(.0008" - .0087") limit .30mm(.0118")
Dan -
  Looking for jdm spec body repair manual AE111 0 978 10-08-2025 10:33 AM
Last Post: AE111
  How to: Repair low fuel warning sender Sanity Clause 3 41,725 05-19-2025 11:05 PM
Last Post: Sanity Clause
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 10,310 07-31-2019 11:28 AM
  Rear arch repair panels TomRich 4 9,493 08-30-2018 09:19 PM
Last Post: zenki
  TRD multi-ECU manual Two Sheds 10 25,812 07-12-2017 12:21 AM
Last Post: jondee86
