Smallport inlet manifold
11-18-2021, 10:38 AM
On the face of it, l admit this may sound a bit daft but hear me out!
Has anyone tried fitting a un-modified smallport inlet into a right hand drive AE86? The regs to which l must now conform forbid any type of inlet manifold modification and l have just aquired a jewel of a smallport engine? Basically the throttle body would face the wrong way! An analogue brain in a digital World |
11-18-2021, 01:20 PM
You could try for the plenum flip instead of cut and shut, the welding will be less apparent. Some grinding and sandblasting might also hide the welding from the casual observer.
These laws sure make life difficult. Verstuurd vanaf mijn Pixel 4a met Tapatalk FABRICA MI DIEM, PVNC! |
11-18-2021, 05:00 PM
I agree the flip well executed might be the best solution. You will have neigh on no space to route the airflow from back to front. Certainly not with a silicon hose. You might be able to redirect the flow with a metal contraption but it would be less than ideal.
AE86 ex-daily |
11-18-2021, 10:23 PM
Ideally flipping it would be done with a TVIS top half.
I wonder if that might be possible? An analogue brain in a digital World |
11-19-2021, 09:36 AM
If you have both, you could measure them up. Havent seen it done before but I would agree that it would look more original.
11-19-2021, 11:50 AM
01-17-2022, 05:14 PM
(11-18-2021 10:38 AM)totta Crolla Wrote: On the face of it, l admit this may sound a bit daft but hear me out! There MIGHT be room... You would need to run a 90 degree elbow... and see if you can make it fit.......... the plenum swap worked quite well in my car ![]() ![]() ![]()
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
| Smallport coil | totta Crolla | 2 | 3,677 |
08-12-2022 11:03 AM Last Post: totta Crolla |
| 4A-GTE 7-rib smallport | nyberrg | 5 | 8,984 |
05-24-2017 09:24 PM Last Post: krullibull |
| Smallport Fuel Rail | Alex170984 | 2 | 6,239 |
11-19-2016 08:44 PM Last Post: Alex170984 |
| Smallport Head swap | Alex170984 | 9 | 12,376 |
06-09-2016 12:11 PM Last Post: ZDoman |
| 4A-GE: Bigport with smallport fuel injection | nyberrg | 7 | 15,420 |
06-13-2015 05:00 PM Last Post: nyberrg |
![AEU86 AE86 - Smallport inlet manifold [Image: AEU86 AE86 - Smallport inlet manifold]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - Smallport inlet manifold [Image: AEU86 AE86 - Smallport inlet manifold]](https://gallery.ostportworks.com/albums/userpics/10005/Blake_s_intake4.jpg)
![AEU86 AE86 - Smallport inlet manifold [Image: AEU86 AE86 - Smallport inlet manifold]](https://gallery.ostportworks.com/albums/userpics/10005/Blake_s_intake2.jpg)
![AEU86 AE86 - Smallport inlet manifold [Image: AEU86 AE86 - Smallport inlet manifold]](https://gallery.ostportworks.com/albums/userpics/10005/Blakes_mod_side_by_side.jpg)
