STL file for the early spec Levin headlight ball joint plastic clip
04-26-2025, 12:01 PM
I own a JDM Levin (early model), and the headlights were in terrible condition. The main problem is that the ball joint that holds the reflector inside the headlight is brittle and breaks, making it impossible to adjust the headlight properly. All the early spec headlights I bought so far had this issue, so I decided to create a 3D model for printing, which I want to share here.
[Image: AEU86 AE86 - STL file for the early spec...astic clip]
You can download the STL file from here.
Use PA11 or PA12 (Nylon) as the material. It is heat-resistant and worked well for me.
Again, this has only been tested for a RHD early model Levin, and I am not sure if it will work on LHD models.
I used this on my own Levin to restore my headlights. If you need more instructions I wrote a summary on my website.
Messages In This Thread
STL file for the early spec Levin headlight ball joint plastic clip - DaLanZhu - 04-26-2025 12:01 PM
  Looking for jdm spec body repair manual AE111 0 981 10-08-2025 10:33 AM
Last Post: AE111
  Converting Jap Spec wing mirrors to UK spec chrisae86 5 4,847 04-12-2022 11:03 PM
Last Post: chrisae86
  Early tvis red top from e9 gti small or bigport? Ryo 3 9,551 04-20-2018 09:14 AM
  AE86 Headlight + wiper wiring (levin) bozu 11 21,800 09-19-2017 02:06 PM
  Trueno headlight help kazi 9 17,039 04-20-2017 09:37 AM
Last Post: kazi
