P-valve CLOSED --> Stiffer spring will do it :)
04-05-2012, 04:17 PM
I'm wondering if I can "pimp" the brake proportional valve by cutting the spring to increase rear brake pressure.
If possible I want to avoid installing adjustable valve for MOT .... My question is basically: Will a shorter spring in the p-valve reduce or increase pressure to the rear brakes? In other words, does the spring close the rear outlet based on a certain hydraulic pressure (differential pressure)? In this case a stiffer spring will increase the rear pressure? Or Is the spring deciding the opening of the outlet? This includes Pressure delay between Front and Rear brakes. In this case softer (cut = less pre-load) spring increases the pressure and reduces delay... The more I think about it the less sure I am ![]() ![]() |
Messages In This Thread |
P-valve CLOSED --> Stiffer spring will do it :) - Dino86 - 04-05-2012 04:17 PM
4A-GE valve shim disintegrated | DaLanZhu | 2 | 586 |
04-30-2025 12:54 PM Last Post: DaLanZhu |
4AGE Valve Buckets Scored | Steller Engineering | 2 | 1,246 |
20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 1,934 |
HKS valve springs | totta Crolla | 3 | 2,695 |
Valve clearance | leon205gti | 7 | 9,340 |
11-25-2016 03:24 AM Last Post: oldeskewltoy |
