P-valve CLOSED --> Stiffer spring will do it :)
04-05-2012, 04:17 PM
I'm wondering if I can "pimp" the brake proportional valve by cutting the spring to increase rear brake pressure.
If possible I want to avoid installing adjustable valve for MOT ....
My question is basically:
Will a shorter spring in the p-valve reduce or increase pressure to the rear brakes?
In other words, does the spring close the rear outlet based on a certain hydraulic pressure (differential pressure)? In this case a stiffer spring will increase the rear pressure?
Or
Is the spring deciding the opening of the outlet? This includes Pressure delay between Front and Rear brakes.
In this case softer (cut = less pre-load) spring increases the pressure and reduces delay...
The more I think about it the less sure I am Confused Confused
  4A-GE valve shim disintegrated DaLanZhu 2 588 04-30-2025 12:54 PM
Last Post: DaLanZhu
  4AGE Valve Buckets Scored Steller Engineering 2 1,246 10-06-2023 05:34 PM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,934 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 2,695 05-25-2022 10:24 PM
  Valve clearance leon205gti 7 9,341 11-25-2016 03:24 AM
