Oil leak (maybe a cylinder head gasket?)
11-26-2013, 04:24 PM
Update: After I removed the front plate I found the camshaft seals leaking and replaced them. Now I will continue to check the leakage at the exhaust manifold side. Maybe it was just the same oil coming down from the camshaft seals.
Fun is not the straight line! |
11-27-2013, 02:15 AM
max_ae86 Wrote:Last year I replaced both cam shaft oil seals, Cap tightened down on the already in place seal, or seal pounded into the already tightened down cap? Sealant between cap & head? |
11-27-2013, 10:29 AM
allencr Wrote:max_ae86 Wrote:Last year I replaced both cam shaft oil seals, Just pounded seal into the already tightened down cap. Fun is not the straight line! |
11-27-2013, 10:46 AM
better take the first caps off, get sealer to correct place and put the seal on place and then tight the cap..
11-30-2013, 03:59 AM
The sealer is to seal the joint between the cap and the head. If you
didn't have the caps off, then you should have no problem just pounding the new seals into the head That's how the FSM says to install them.Cheers... jondee86 |
| Bigger brake master cylinder options | Koen | 10 | 4,064 |
01-08-2026 03:12 PM Last Post: r.ave |
| 4AGE cylinder head plug removal | Ivan141 | 5 | 5,929 |
| Brake advice - master cylinder | mannix20vt | 12 | 20,660 |
| AE86 w/MX-5 swap, maybe?? | cke70 | 13 | 21,196 |
05-31-2016 08:30 PM Last Post: cke70 |
| Correct connection brake master cylinder? | bozu | 5 | 10,329 |
