Oil leak (maybe a cylinder head gasket?)
11-18-2013, 10:36 AM
jondee86 Wrote:Are you sure it is not leaking down from the cam cover gasket ? I don't know. I also found a small leak below the cam shaft pulleys after I removed the front timing belt cover. Maybe I should order full cylinder head gasket set from toyota and rebuild complete upper part of the engine Fun is not the straight line! |
| Messages In This Thread |
Oil leak (maybe a cylinder head gasket?) - max_ae86 - 11-18-2013, 09:50 AM
[] - max_ae86 - 11-18-2013 10:36 AM
[] - corolla4agze - 11-18-2013, 11:36 AM
[] - Alex170984 - 11-18-2013, 05:44 PM
[] - corolla4agze - 11-27-2013, 10:46 AM
| Bigger brake master cylinder options | Koen Bongers | 4 | 371 |
Today 06:16 PM Last Post: r.ave |
| 4AGE cylinder head plug removal | Ivan141 | 5 | 3,803 |
| Brake advice - master cylinder | mannix20vt | 12 | 17,473 |
| AE86 w/MX-5 swap, maybe?? | cke70 | 13 | 17,622 |
05-31-2016 08:30 PM Last Post: cke70 |
| Correct connection brake master cylinder? | bozu | 5 | 8,757 |
