OST-125: Building a big valve 5AGTTE (yes, twin turbocharged)
10-27-2026, 01:02 AM
(This post was last modified: 10-27-2026 01:03 AM by oldeskewltoy.)
So, moving to the block, and preparing it for stroker use.
1st, the block gets clean enough to eat off.... ![]() and then the machining begins... (torque plate in place) Getting the new bores to fit the new pistons - minus 6cc dome. ![]() Next some extra room is needed at the bottom of the cylinder bores. ![]() ![]() ![]() more to come....
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-29-2026, 03:22 PM
That's some serious modification of all parts of the engine. Always enjoy reading your posts!
10-30-2026, 10:07 PM
and now things get a bit tighter...
11-04-2026, 06:20 PM
So typically I use Eastwood's metal blackening system for the outside of the block...
![]() As it mimics the original black oxide coating rather well. But this client wants something a bit brighter..... So we begin this job with a 2 part epoxy primer.... ![]() And after 24 hours, the top coat gets applied - Aluminum/Silver ![]() Think we'll need some shades So curing begins, now to wait........... more to come....
11-09-2026, 09:58 PM
(10-30-2026 10:07 PM)oldeskewltoy Wrote: [ -> ]and now things get a bit tighter... And to provide enough room under the block, a block spacer. This will provide enough room for the bigger crank to clear the windage tray ![]() more to come....
| (Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 4,896 |
| OST-093: My, My, Mystery | oldeskewltoy | 10 | 10,248 |
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 6,882 |
| (Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 4,635 |
| (Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 3,670 |
![AEU86 AE86 - OST-125: Building a big val...bocharged) [Image: AEU86 AE86 - OST-125: Building a big val...bocharged)]](https://gallery.ostportworks.com/albums/userpics/10005/cleaned_block.jpg)
![AEU86 AE86 - OST-125: Building a big val...bocharged) [Image: AEU86 AE86 - OST-125: Building a big val...bocharged)]](https://gallery.ostportworks.com/albums/userpics/10005/normal_traum_piston_number_removed.jpg)
![AEU86 AE86 - OST-125: Building a big val...bocharged) [Image: AEU86 AE86 - OST-125: Building a big val...bocharged)]](https://gallery.ostportworks.com/albums/userpics/10005/stroker_clearance_bottom_of_block.jpg)
![AEU86 AE86 - OST-125: Building a big val...bocharged) [Image: AEU86 AE86 - OST-125: Building a big val...bocharged)]](https://gallery.ostportworks.com/albums/userpics/10005/normal_stroker_clearance_bottom_of_block2.jpg)
![AEU86 AE86 - OST-125: Building a big val...bocharged) [Image: AEU86 AE86 - OST-125: Building a big val...bocharged)]](https://gallery.ostportworks.com/albums/userpics/10005/normal_stroker_clearance_bottom_of_block1.jpg)
![AEU86 AE86 - OST-125: Building a big val...bocharged) [Image: AEU86 AE86 - OST-125: Building a big val...bocharged)]](https://gallery.ostportworks.com/albums/userpics/10005/normal_squirter_clearance_2.jpg)
![AEU86 AE86 - OST-125: Building a big val...bocharged) [Image: AEU86 AE86 - OST-125: Building a big val...bocharged)]](https://gallery.ostportworks.com/albums/userpics/10005/normal_squirter_clearance_1.jpg)
![AEU86 AE86 - OST-125: Building a big val...bocharged) [Image: AEU86 AE86 - OST-125: Building a big val...bocharged)]](https://gallery.ostportworks.com/albums/userpics/10005/block_with_coating_before_and_after_2_panel.jpg)
![AEU86 AE86 - OST-125: Building a big val...bocharged) [Image: AEU86 AE86 - OST-125: Building a big val...bocharged)]](https://gallery.ostportworks.com/albums/userpics/10005/epoxy_primer_3_panel.jpg)
![AEU86 AE86 - OST-125: Building a big val...bocharged) [Image: AEU86 AE86 - OST-125: Building a big val...bocharged)]](https://gallery.ostportworks.com/albums/userpics/10005/painted_block_3_panel.jpg)
![AEU86 AE86 - OST-125: Building a big val...bocharged) [Image: AEU86 AE86 - OST-125: Building a big val...bocharged)]](https://gallery.ostportworks.com/albums/userpics/10005/pan_spacer.jpg)
