OST-058: "Q"
09-28-2019, 05:14 PM
OST-058: "Q"
![]() more to come......
09-28-2019, 08:41 PM
OST-058: "Q"
10-01-2019, 12:12 AM
OST-058: "Q"
(09-28-2019 08:41 PM)banpei Wrote: Not a whole lot going through my mind....... ![]() Recently I've acquired 5 20V 4AG heads. Two Silvertop, and three Blacktop ![]() One of the Blacktop heads went to a client in Indiana, this head is #2 from that lot.... and it is available.... disassembled, ready to get cleaned ![]() more to come....
10-01-2019, 08:26 PM
OST-058: "Q"
the head came back pretty clean...
This was the first 20V head I spent any time on deburring the casting flash ![]() Most of the casting flash was around the spark plug tube supports, and in the end areas. Some of the area are purposefully cast with a ledge, those areas stand out around the exhaust side bucket cylinders More to come......
10-03-2019, 03:07 AM
(This post was last modified: 10-03-2019 03:07 AM by oldeskewltoy.)
OST-058: "Q"
and so it begins.... biggest thing on a Blacktop head is core shift... you can kind of see it in top photo's short radius as it isn't centered
![]() Chamber #2 on top, chamber #1 on the bottom.... You can also see where I've done blending around the valve seats more to come......
10-03-2019, 05:27 PM
OST-058: "Q"
working the bowls to correct the core shift, and to create "gentle" short radii.....
10-04-2019, 01:12 AM
OST-058: "Q"
2 down... 2 to go....
10-14-2019, 06:21 PM
OST-058: "Q"
with the port work finished, its off to the machine shop to get its valve job, and re-surfacing
10-22-2019, 06:47 PM
OST-058: "Q"
back from its valve job(ain't those back cuts purdy..... ), and re-surface... ready for re-assembly.
![]() more to come.... ![]() PS... this head still needs a new owner....... Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
| (Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 4,163 |
| OST-093: My, My, Mystery | oldeskewltoy | 10 | 8,467 |
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 5,802 |
| (Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 3,846 |
| (Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 3,053 |
![AEU86 AE86 - OST-058: "Q" [Image: AEU86 AE86 - OST-058: "Q"]](http://ost.ebeans.ch/albums/userpics/10005/ost-058.jpg)
![AEU86 AE86 - OST-058: "Q" [Image: AEU86 AE86 - OST-058: "Q"]](https://media2.giphy.com/media/U1OKW64UYY5Fu/giphy.gif?cid=790b76112dddb87016deba27c02e0e21b47966dccbaf4294&rid=giphy.gif)
![AEU86 AE86 - OST-058: "Q" [Image: AEU86 AE86 - OST-058: "Q"]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - OST-058: "Q" [Image: AEU86 AE86 - OST-058: "Q"]](http://ost.ebeans.ch/albums/userpics/10005/20V_inventory_smaller.jpg)
![AEU86 AE86 - OST-058: "Q" [Image: AEU86 AE86 - OST-058: "Q"]](http://ost.ebeans.ch/albums/userpics/10005/disassembled_before_cleaning_smaller.jpg)
![AEU86 AE86 - OST-058: "Q" [Image: AEU86 AE86 - OST-058: "Q"]](http://ost.ebeans.ch/albums/userpics/10005/deburred_casting.jpg)
![AEU86 AE86 - OST-058: "Q" [Image: AEU86 AE86 - OST-058: "Q"]](http://ost.ebeans.ch/albums/userpics/10005/intake_ports_2_panel~0.jpg)
![AEU86 AE86 - OST-058: "Q" [Image: AEU86 AE86 - OST-058: "Q"]](http://ost.ebeans.ch/albums/userpics/10005/comparing_valves_2__22C3_to_42C5_smaller_1200_wide.jpg)
![AEU86 AE86 - OST-058: "Q" [Image: AEU86 AE86 - OST-058: "Q"]](http://ost.ebeans.ch/albums/userpics/10005/2_down_2_to_go~0.jpg)
![AEU86 AE86 - OST-058: "Q" [Image: AEU86 AE86 - OST-058: "Q"]](http://ost.ebeans.ch/albums/userpics/10005/4_down_2.jpg)
![AEU86 AE86 - OST-058: "Q" [Image: AEU86 AE86 - OST-058: "Q"]](http://ost.ebeans.ch/albums/userpics/10005/ready_for_reassembly.jpg)
