OST-050 - a VERY special build
10-31-2018, 01:37 AM
Post: #35
RE: OST-050 - a VERY special build
(10-17-2018 09:18 PM)Bean Wrote: Best of luck Dan, getting paint codes was and always will be a headache. Hope it turns out well so you can cross it off the list and store the details for it in your knowledge base for the future. we shall see.......... from another forum Wrote:Hi Guys, I use oem code 147 silver metalic or 148 would do the trick if you like it painted. i use 147 and work great on my coupe valve covers. they turn to a gold ish silver color with the engine heat after a couple of drives but still looks good. and hard to tell the difference. see below.... but I may contact you if............... oldeskewltoy Wrote:another big BUT... the powder coater knows a painter, and he uses automotive grade paints (not removed with Brake, or Carb cleaners), and not only that he works with a paint supplier who has color matching capability... :mrgreen: How many guessed this wasn't going to work??? I got a text 2 days later.... "I took a look at them last night and it's something I'm not able to do. It's a very long process. I just wouldn't have the time to do so. Lots of time and work has to be put into those. I'd try a restoration shop! I'm sorry I couldn't help" Really??? So, in the meantime.... I MAY have found someone to do the job... but as before, I'm waiting..... sooooooooooo........ assembly begins.... the new cooling system... ![]() next the reman TVIS assembly ![]() followed by the intake manifold ![]() Oh most of the hardware is new, only a few bolts were re-used (cleaned) more to come.......
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
| (Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 4,641 |
| OST-093: My, My, Mystery | oldeskewltoy | 10 | 9,616 |
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 6,454 |
| (Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 4,316 |
| (Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 3,450 |
![AEU86 AE86 - RE: OST-050 - a VERY special build [Image: AEU86 AE86 - RE: OST-050 - a VERY special build]](http://ost.ebeans.ch/albums/userpics/10005/engine_assembly_-_cooling_mounted.jpg)
![AEU86 AE86 - RE: OST-050 - a VERY special build [Image: AEU86 AE86 - RE: OST-050 - a VERY special build]](http://ost.ebeans.ch/albums/userpics/10005/engine_assembly_-_cooling2C_and_TVIS_mounted.jpg)
![AEU86 AE86 - RE: OST-050 - a VERY special build [Image: AEU86 AE86 - RE: OST-050 - a VERY special build]](http://ost.ebeans.ch/albums/userpics/10005/engine_assembly_-_cooling2C_TVIS2C_and_intake_mounted.jpg)
