OST-045: 5AGTE... again ;)
01-18-2018, 12:46 AM
[Image: AEU86 AE86 - OST-045: 5AGTE... again ;)]
As arrived. The head has been cleaned, but I don't know if it has also be pressure tested, so I'll be sending it out, along with all the associated bits to get cleaned and pressure checked before I start work.
The buckets and shims have seen better days... replacing them with good used units is far less costly then trying to salvage these
More to come....... Hurray!
Dan -
01-19-2018, 07:57 PM
work begins.... de-burring the casting......
more to come...... Hurray!
Dan -
01-23-2018, 04:20 AM
working the first set of bowls and seats.....
more to come....... Hurray!
Dan -
01-25-2018, 02:03 AM
2 down.... 2 to go....
Dan -
01-26-2018, 08:33 PM
Just about done on the intake side.........
more to come..... Hurray!
Dan -
01-27-2018, 02:41 AM
next... the exhaust side....
more to come........ Hurray!
Dan -
02-01-2018, 12:05 AM (This post was last modified: 02-01-2018 12:15 AM by oldeskewltoy.)
Chamber work has begun.....
Dan -
02-05-2018, 10:51 PM
3 chambers down......
sometimes the right tool is the simplest.... working the chamber wall with 120 grit. Wink
more to come.... Hurray!
Dan -
02-08-2018, 05:51 PM
Chambers done...... (for now)
work begins on the exhaust side.... one done... one under construction
Dan -
02-09-2018, 02:11 PM
Dan
Have you send any dyno testing that would indicate that the 4AGE would see favorable power gains by incorporating anti-reversion step in the exhaust port - header. I've already increased the exhaust port by about 3mm, but was thinking about grinding out the header I.D. at the head attachment face. Dave W
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 4,201 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 8,578 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 5,849 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 3,896 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 3,094 06-28-2022 09:17 PM
