No idle below 2000 rpm rich running
11-28-2022, 05:34 PM
Good afternoon its finally time to run our restoration project up but I'm struggling with it running far too rich so hopefully someone here can point me in the right direction.
Its an ex BSCC touring car from 1986 that I came to in a state of partial rebuild and have had to source parts and attempt to re engineer some other bits
As far as I can tell I have the original loom, ignition pack, ecu and some injectors from Flo and it started first hit of the button with a bit of extra throttle. but a post collector lamda sensor is giving me a constant 0.8 and it will stall out below 1500 rpm having got it warm and tried swapping out fuel pressure regulators and resetting the throttle pot it wouldnt restart because the plugs were too fouled, cleaned them up and refitted and it starts again at least.
What might I have missed that would allow it to start but run rich?
11-28-2022, 08:28 PM
Map-Sensor ist ok ?
11-28-2022, 11:59 PM
If it still has the original ecu check you have the correct injectors for it.
11-30-2022, 02:45 PM
Have you checked the timing?
  Blacktop 20V high idle Bravothreezero 3 610 08-28-2026 01:11 PM
Last Post: jdm86gtz
  Running issues sam3007 6 5,943 06-26-2022 01:34 PM
Last Post: Dave W
  Engine starts/revs but no idle GenkiMotors 17 14,445 11-20-2021 04:12 AM
Last Post: GenkiMotors
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 12,097 11-09-2020 10:51 AM
Last Post: totta Crolla
  exhaust odor/idle MOT issue Ryo 7 11,201 07-15-2019 09:17 AM
Last Post: jondee86
