MAXGRIP 7.5" Supra LSD kits
03-17-2009, 07:41 AM
MAXGRIP Supra 7.5". A real performance rebuild kit for the O.E.M. Supra LSD. These parts have been designed to get the maximum grip possible with the o.e.m. LSD! The kit comes with new stationary plates and new clutch plates that were normally not installed from the factory. Adding these two clutch plates increases the overal friction surface area 4X or 200% more than the typical factory LSD. Also included are new reversible solid bronze thrust washers, spiral grooved for oiling. You also get new heavy duty springs and complete shim kit (16 assorted thicknesses) for setting the clearances within the LSD to exact specs for best performance. Using this kit, your LSD will be more responsive, lock faster, with maximum grip! No more one tire fire!
[Image: AEU86 AE86 - MAXGRIP 7.5" Supra LSD kits]
This is a great alternative to the more expesive aftermarket LSD's! We also have a kit for the O.E.M. GTS LSD and plan on producing kits for Mazda and others soon.
Since this LSD is very similar to the AE86 you can use the install instructions for the MAXGRIP GTS kit: http://forums.club4ag.com/zerothread?id=31135
$190.00 plus ship and CA sales tax if applicable. Thanks!
Spence Weir
Weir Performance Engineering LLC
707-315-6638
[email protected]
  Group A --- Body Kits Jblood, Vertex, RunFree, Goodline Group A 20 46,614 03-20-2013 10:01 PM
Last Post: alimonos
  Wilwood Brake Kits €600 each ep71 14 38,913 01-18-2013 01:04 AM
Last Post: TheGerman
  Track and road brake kits ep71 12 18,991 09-17-2012 10:28 AM
Last Post: ep71
  MCNSPORT.com FRP & CarbonFibre Products - Prices & P MCNSPORT.com 49 78,603 09-16-2009 04:26 PM
Last Post: MCNSPORT.com
  P.A.S.S - D-Max, Runfree, Vertex, CBY, Goodline, Jblood KITS SYM 41 68,103 07-31-2009 11:20 AM
Last Post: SYM
