Krullibulls Ae86 BEAMS is the only way
03-21-2017, 11:12 PM
Post: #67
RE: Krullibulls Ae86 BEAMS is the only way
Long time, no post!
The beams worked great all summer, did 3 driftdays and some light commuting(!). Wasn't great at it tho with fuel consumption of 20L/100km ![]() But at the end I started getting heavy vibrations in 3rd and 4th, barely anything on the other gears and it disappeared when I depressed the clutch so the gearbox is probably crap. Bring on the pics! ![]() Finally bought myself a lift! ![]() ![]() Took the ITBs off for a clean and milling. Printed some plugs for the bearings and seals. ![]() Started tearing down the car again... ![]() ITBs milled out to 48mm, plastic blasted and painted. ![]() Teardown of the gearbox with the help of 2 friends and no service manual. Only thing wrong we found was that the ring for the shifter fork for 3&4th had moved too far. ![]() ![]() More teardown of the car. ![]() ![]() Had to take off the flywheel to get the engine on the stand. Turns out my cheap clutch is shit ). On the preassure plate side it had only engaged on the outer ~1.5cm.![]() Not much left inside now. ![]() The deliveryman dropped of a pile of tubes. Looks like I can make them fit inside the 'rolla ![]() Bought a notcher with proper C E (China Export) quality. All the hardware changed out from 4.8 (wtf!?) to 8.8 and new bushings ordered for the shaft since the play was ridiculous. And that's were we at right now. I will not be driving it this year but instead "finish" it with cage, all new body wiring, equal length 4-links, new wheels?, some more stuff and finally! Paint! |
| ae86 racecar with beams engine | bakonick | 151 | 217,960 |
06-02-2026 10:33 PM Last Post: bakonick |
| OST-078: Not the only one who signs their work..... | oldeskewltoy | 9 | 8,107 |
02-03-2022 08:52 PM Last Post: oldeskewltoy |
| Aram's 3SGE Beams Levin Coupe | robokill | 665 | 933,035 |
| AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides | Conrad | 462 | 742,127 |
| Beams Levin build | mannix20vt | 5 | 12,614 |
01-27-2016 12:39 AM Last Post: mannix20vt |
![AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way [Image: AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way]](http://imagizer.imageshack.us/v2/800x600q90/921/tL1dUU.jpg)
![AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way [Image: AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way]](http://imagizer.imageshack.us/v2/800x600q90/921/agNwlN.jpg)
![AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way [Image: AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way]](http://imagizer.imageshack.us/v2/800x600q90/924/fFCrr8.jpg)
![AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way [Image: AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way]](http://imagizer.imageshack.us/v2/800x600q90/921/YwOdAc.jpg)
![AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way [Image: AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way]](http://imagizer.imageshack.us/v2/800x600q90/922/UqmmIb.jpg)
![AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way [Image: AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way]](http://imagizer.imageshack.us/v2/800x600q90/924/EeIt1L.jpg)
![AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way [Image: AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way]](http://imagizer.imageshack.us/v2/800x600q90/922/Uz97kQ.jpg)
![AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way [Image: AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way]](http://imagizer.imageshack.us/v2/800x600q90/921/WofCjz.jpg)
![AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way [Image: AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way]](http://imagizer.imageshack.us/v2/800x600q90/924/i65img.jpg)
). On the preassure plate side it had only engaged on the outer ~1.5cm.![AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way [Image: AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way]](http://imagizer.imageshack.us/v2/800x600q90/922/zPwG2k.jpg)
![AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way [Image: AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way]](http://imagizer.imageshack.us/v2/800x600q90/924/XRdS4V.jpg)
![AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way [Image: AEU86 AE86 - RE: Krullibulls Ae86 BEAMS is the only way]](http://imagizer.imageshack.us/v2/800x600q90/924/GEw38r.jpg)
