Kaaz 1.5 way Diff - Driveshaft Compatability
05-09-2021, 07:57 PM
Hi all, my kouki jap spec 86 has a standard diff with no lsd. I've decided to go with a Kazz 1.5 way diff. Do I need to measure the shaft first prior to ordering?
I'm aware the zenki drive is different but is there anything else I need to check compatability wise? |
05-10-2021, 01:02 PM
The axle shaft are the only things you need to check. Everything else is the same as long as it's an AE86 rear end (6.7" ring and pinion).
| AE86 Driveshaft too long? [SOLVED] | MyCrazyGarage | 12 | 13,297 |
07-28-2022 10:48 PM Last Post: banpei |
| Help needed: is it 1 way or 1.5way LSD | Dino86 | 2 | 5,228 |
| Tomei 16V poncams + Tomei technical trax 1.5 way LSD | Lt86 | 22 | 27,254 |
09-16-2016 09:56 PM Last Post: Alex170984 |
| Driveshaft free play | thanos | 6 | 12,312 |
02-25-2015 02:10 AM Last Post: thanos |
| Driveshaft question | DidiDex | 3 | 7,367 |
02-12-2015 09:43 AM Last Post: DidiDex |
