How to restore my bumpers to former glory?
10-31-2006, 02:50 PM
Hi!
Because my car has changed hands many times before it got to me, the bomper hve gotten red from the original black-plastic-unclored.. as i want to make the car to look stock, i would like to "scrub" the paint off the bumpers, make them black again.. maybe paint the top in color and leave oly the bottom black. But i dont know how to recondition them? Should i sand-blast them or what? And i dont want them to be smooth and shiny black, so i would like not to color them, or i dunno use black- very mat color? please do advise. tnx,s. |
10-31-2006, 03:40 PM
At least some industrial paints are available in different levels of glossiness so you could choose a semi-gloss black paint as a base. You'll probably need to add a bit of elasticity additive to it to keep the paint from flaking if the bumper gets bent or hit. Finally, some paint manufacturers have a "texturizer" additive which causes the paint to cure with an uneven surface, much like what the original plastic molded surface looked like. I think this would result in a surface that's pretty close to stock as you can get by painting.
At least Spies-Hecker has this additive which is being advertised for repairing bumpers, etc. They also have an elastic additive which is probably a good idea to use on a bumper. I've been using Tikkurila paints and they have similar products available - however, they're a finnish manufacturer so their paints may not be as commonly available. |
11-01-2006, 02:18 PM
Thanx, for the info, hopefully they'll have something similar here..
Still the question remains, how do i get the paint and the kit off? My rear bumper started cracking, and big thick chunks of kit and paint are falling off. I really dont wanna die sanding off this thick layer of kit, could i sand-blast the paint off? or use some (di)solvant that would not disolve the bumper? And also what should i use for primer on the bumpers, so the new paint sticks well? |
11-01-2006, 05:52 PM
I believe brake fluid does wonders for stripping paint without damaging plastic parts (like thinner would). Just use a testspot somewhere inconspicous and give it a go... I use it on models some times.
11-01-2006, 06:05 PM
brake fluid huh thats a great tip
i know they have this stuff for black trims its call BACK TO BLACK that might work on the bumpers Max [email protected] |
11-01-2006, 06:18 PM
thanx for the tips guys, i'll give it a go, see what ill find.
| Some information for those who are about to restore their differential | krullibull | 0 | 3,983 |
06-06-2015 12:44 AM Last Post: krullibull |
| show me your front bumpers!! and identify mine | koh | 7 | 8,114 |
04-08-2008 01:48 AM Last Post: koh |
| How to remove my bumpers | James | 9 | 14,515 |
10-30-2005 05:39 PM Last Post: Mux213 |
