High rev problem
07-03-2013, 12:05 AM
I am puzzled also Tongue On a 20V engine, all of the idle air usually goes
thru the ISCV. If you block the ISCV hose, the engine will either stall, or
struggle to keep running at 400-500 rpm. So I wonder what hose you
have blocked, and how the engine can idle without air ?? Did you adjust
the throttle arm stop screw to keep the throttles slightly open ?
Cheers... jondee86
Messages In This Thread
High rev problem - stratosTRD - 06-29-2013, 07:41 PM
[] - jondee86 - 07-01-2013, 02:19 AM
[] - fax0815 - 07-01-2013, 03:10 AM
[] - fax0815 - 07-02-2013, 07:30 PM
[] - stratosTRD - 07-02-2013, 09:44 PM
[] - jondee86 - 07-03-2013 12:05 AM
  High-beam warning lamp Mylesmck 4 4,034 07-21-2023 07:44 AM
  Engine stress at high speeds gh0st 6 5,606 08-30-2022 07:11 PM
Last Post: Power_uP
  4AGE 16V engine overheat when at high speed chenfon 32 36,250 12-31-2020 06:39 AM
Last Post: chenfon
  Early EDM non-cat 4A-GE 16v Bluetop Fails emissions (high co) Rascal21 41 48,906 08-21-2016 04:51 PM
Last Post: ray
  Raising the rev limit on stock ECU fax0815 2 13,465 08-31-2015 02:04 PM
Last Post: gon
