Gear Box option - again?
08-28-2009, 06:48 AM
I know this topic might being discuss for ages!
really want to change my T50 as it rattle all the time, although new syn and bearing replaced. bushing on the TRD short Any suggestion on a 6 speed gear box? I know CBY has a custom bellhousing for the GX100 6 speeder, but it just far too expensive. |
08-28-2009, 07:20 AM
The other reasonable way to go is Altezza SXE10 / Mazda Miata 1.8 / Honda S2K / S15 gear box - 6 speed...
Ex-owner of JDM 83' Trueno Coupe DCw Classic, classic cars restoration, JDM wheels & parts import, sales. http://www.facebook.com/DogCustomWorks +37067170000 |
08-28-2009, 11:35 AM
but how to solve the different bell housing matching problem.
Even for the SXE10, it cant bolt directly to the 4A, any body has done such a similar swap before? thanks to advise |
10-11-2009, 09:45 PM
KD2229 Wrote:but how to solve the different bell housing matching problem. Heres how ![]() ![]() ![]() ![]() ![]() ![]() T50 and altezza housings matted together The only "cheap" way to go.
10-11-2009, 10:20 PM
actually..........
here is another way.... ![]() ![]() As you see, the adapter is finished, and now so is the custom input shaft. The reason this isn't in production is simple... there was never enough demand shown to invest the €12,000 - €15,000 needed to put the 1st 25 kits into production. This "kit" would cost about €1500 per kit. This kit was designed to be used with the AZ6 from the Mazda MX5 Miata. The AZ6 "we" know is the J160, and uses a different tail housing, and has different ratios. Oh... the S2000 Honda does NOT use this gearbox. The cars using this gearbox are the S15 GT-R, the Altezza GXE and SXE10, the RX8, the MX5. Here are the different factory ratios.... S15 6 spd 3.626 2.200 1.541 1.213 1.000 0.767 RX8 6 spd 3.760 2.269 1.645 1.187 1.000 0.843 Miata 6-spd 99- 3.760 2.269 1.645 1.257 1.000 0.843 SXE10 6 sp 3.874 2.175 1.484 1.223 1.000 0.869 Besides the factory gear sets, HKS makes a set or 2(over $10,000) and TRD makes a set. The S15 drivers have the highest failure rate, their mass, and torque and grip levels are what kills this transmission - S15 is 2800#s, and over 205#/ft of torque There isn't a Corolla anywhere that would have that combination of mass and torque... the likelyhood of breaking an AZ6 is minimal at best Here are more details - http://www.aeu86.org/viewtopic/t50-to-az...ues/t/4283 Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
11-25-2009, 11:31 AM
Hey Doggy,
Nice pic you have there, where can I get one of this. Very interesting |
11-25-2009, 12:20 PM
KD2229 Wrote:Hey Doggy, The EASYEST way would be just to get it build by some one who knows what hes doing. But once again - you would need to have BOTH bell housings too... Ex-owner of JDM 83' Trueno Coupe DCw Classic, classic cars restoration, JDM wheels & parts import, sales. http://www.facebook.com/DogCustomWorks +37067170000 |
11-25-2009, 01:50 PM
nice,
I will try to do one. |
11-26-2009, 04:56 PM
well, few more question.
what about the input shaft, use the T50 one or SEX one. And, total length of the gear box, need to modify the drive shaft to fit. Thanks for the advise Rgds, Yung |
11-26-2009, 05:25 PM
KD2229 Wrote:well, few more question. You should answer this one your self once you see both gearboxes Ofcorse you will going to use SXE one - cuz there is no way to use T50 one Take a look at the pics - study them - and you will see everything. You will have to get custom clutch disk build to support SXE shaft and carry corolla disk size. Here: http://blog.livedoor.jp/cb_yokohama/arch...08-04.html Go and browse this blog you will find all the info you need there
| Clicking noise from glove box | chrisae86 | 4 | 4,416 |
09-08-2022 11:36 PM Last Post: chrisae86 |
| 5th gear issue | r.ave | 1 | 4,350 |
03-14-2021 08:52 PM Last Post: Ivan141 |
| ring gear bolts | DJexor | 3 | 7,558 |
12-26-2016 10:56 PM Last Post: totta Crolla |
| T50 gearbox - TRD 2nd and 3rd gear | hachirokkos | 3 | 8,427 |
11-27-2015 10:06 AM Last Post: Project D |
| Decently heavy vibration in fourth gear between 2000-2300rpm | dinkers542 | 4 | 7,312 |
11-29-2014 12:27 AM Last Post: dinkers542 |
![AEU86 AE86 - Gear Box option - again? [Image: AEU86 AE86 - Gear Box option - again?]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_3315_resize.jpg)
![AEU86 AE86 - Gear Box option - again? [Image: AEU86 AE86 - Gear Box option - again?]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_3316_resize.jpg)
![AEU86 AE86 - Gear Box option - again? [Image: AEU86 AE86 - Gear Box option - again?]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_3317_resize.jpg)
![AEU86 AE86 - Gear Box option - again? [Image: AEU86 AE86 - Gear Box option - again?]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_3318_resize.jpg)
![AEU86 AE86 - Gear Box option - again? [Image: AEU86 AE86 - Gear Box option - again?]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_3319_resize.jpg)
![AEU86 AE86 - Gear Box option - again? [Image: AEU86 AE86 - Gear Box option - again?]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_3320_resize.jpg)
![AEU86 AE86 - Gear Box option - again? [Image: AEU86 AE86 - Gear Box option - again?]](http://i79.photobucket.com/albums/j143/oldeskewltoy/AZ6/collageofadapter.jpg)
![AEU86 AE86 - Gear Box option - again? [Image: AEU86 AE86 - Gear Box option - again?]](http://i79.photobucket.com/albums/j143/oldeskewltoy/AZ6/belltotranscollage.jpg)
