Diff problem
08-25-2014, 12:47 PM
Diff problem
(08-25-2014 10:44 AM)jondee86 Wrote:  Anything that changes the point of contact between crown wheel and pinion
could potentially lead to a whine from the diff. But if the mechanic replaced
the pinion bearings, I should think that he set the pre-load correctly.
Last time I researched this question (as it comes up regularly) I believe that
I read that the noise is a resonant frequency generated by the teeth of the
pinion striking (contacting) the teeth of the crown wheel. Typically the
noise will be speed related, rising to a maximum at a certain speed, and then
fading away as the speed increases.
In effect, the crown wheel is ringing like a bell under the impact of the
pinion teeth. Settin the pinion depth incorrectly is said to be one possible
cause (contact patch not in the centre of the tooth face).
Cheers... jondee86
I re-checked the contact myself anf it's correct.
Envoyé depuis mon GT-I9100 avec Tapatalk
  4agZe problem solved - 99% IC problem Okami 41 46,416 07-12-2012 04:49 PM
Last Post: Okami
  What Diff Oil For a Clutch plate diff? jamieae86 10 17,470 12-16-2011 11:14 AM
Last Post: bakonick
  weight diff head diff center fax0815 5 8,608 12-21-2010 03:03 PM
Last Post: fax0815
  AC problem? Idle problem? KD2229 3 6,182 08-19-2009 02:08 AM
Last Post: KD2229
  Celica F-diff with Hilux/ Pickup Torsen diff Roye 7 13,866 04-29-2008 09:13 PM
Last Post: Roye
