DLI GZE no spark
04-10-2011, 08:34 PM
DLI GZE no spark
My map DLI GZE has a no spark issue, it ran last year set up the exact same way, last night I re-assembled everything and when I turn it over it sputtered a couple times and that was it, ajd then no spark... I've checked for power at coils, ignitor, ECU.. Everything checks out....
Tried a spare coil I had, ECU and cam angle sensor and no luck, engine is getting fuel as it's soaking the plugs, I've run out of ideas on what to check anymore |
04-10-2011, 08:42 PM
DLI GZE no spark
If power is OK and your spares dont work I would start to look at the ground points.
04-10-2011, 09:08 PM
DLI GZE no spark
Ive already took a booster cable and hooked it up from the battery straight to the engine... still nothing
04-10-2011, 10:27 PM
DLI GZE no spark
Get a new set of plugs (cheapest copper core that meet specs) and try
them. Make sure the igniter is firmly grounded. Cheers... jondee86 |
02-01-2013, 07:05 PM
DLI GZE no spark
jondee86 Wrote:Get a new set of plugs (cheapest copper core that meet specs) and try suppose i should update this in case someone has the same issue, turned out after all it was the plugs, when we took the line off the plug and grounded it out it was fine, spark just wasnt getting through the plugs, even though they hadnt even had 2 hours of run time |
| Weak spark, doesn’t start. | AlexFourTwenty | 4 | 18,699 |
| 20v no spark & dry plugs. | Rascal21 | 26 | 44,115 |
05-10-2013 02:47 AM Last Post: Rascal21 |
| Spark Plugs on modded 16v | apardal | 1 | 4,954 |
03-15-2012 08:14 PM Last Post: apardal |
| GZE Swop with PAS & AC | Lauren | 12 | 17,971 |
02-16-2012 01:04 PM Last Post: heshan |
| Engine sounds slush GZE with VIDEO ! | Okami | 13 | 19,058 |
01-03-2012 12:12 PM Last Post: Okami |
