Correct connection brake master cylinder?
07-19-2015, 08:43 PM
Gents,
I'm currently rebuilding my car and recently installed a new brake master cyl. Just want to double check if it is connected properly now to the proportioning valve block.
See picture below, can someone confirm?
[Image: AEU86 AE86 - Correct connection brake master cylinder?]
AE86 Levin
07-23-2015, 06:28 PM
No one?
AE86 Levin
07-23-2015, 10:38 PM
(07-23-2015 06:28 PM)bozu Wrote:  No one?
It's a bit hard to see to be honest
07-24-2015, 07:31 AM
The side connection of the bmc goes to the left top of the proportioning valve and de back connection of the bmc goes to the left bottom of the proportioning valve
AE86 Levin
07-25-2015, 03:45 AM
AFAIR there are letters casted on valve... look them up.
07-26-2015, 12:28 PM (This post was last modified: 07-26-2015 12:30 PM by bozu.)
I'm only interested in the connection with the bmc. The other ones ive got.
On the left top of the valve there is a 'F' and left bottom an arrow pointing in to the valve.
I would assume F stands for feed but why is there also an arrow pointing in.
On the bmc there is a letter on one port which looks like an F or a P. Ive connected that port to the F on the valve.
Ive already tried to look it up in the manual but no luck. Hence why i'm asking here.
Just want to double check, don't want to have to change it after everything is bled.
AE86 Levin
  Bigger brake master cylinder options Koen 10 2,745 01-08-2026 03:12 PM
Last Post: r.ave
  4AGE cylinder head plug removal Ivan141 5 5,099 09-30-2023 09:47 PM
  Brake advice - master cylinder mannix20vt 12 19,306 08-21-2017 03:21 PM
Last Post: Project D
  torque setting head cylinder bolts izanagi 1 6,650 05-29-2015 01:23 AM
  Dimensions clutch master cylinder bozu 2 7,994 04-16-2015 07:11 AM
Last Post: bozu
