Clutch Master Cylinder and Clutch Slave Cylinder fitment?
06-30-2009, 04:07 PM
Does anyone know can I use a AE111 Clutch Master Cylinder and Clutch Slave Cylinder on my Kouki AE86 without any modification?
07-01-2009, 07:48 AM
I don't know for a fact, but I would consider it extremely unlikely. The
AE86 slave bolts to a boss on the side of the bell housing, and the fixing holes would need to be identical... and the bore size... and the alignment of the hose connector. The master also has to fit the existing mounting holes (unless you don't mind drilling) and again the bore size and pipe tappings need to match for a bolt-on installation. Good luck ![]() Cheers... jondee86 |
| Bigger brake master cylinder options | Koen | 10 | 2,747 |
01-08-2026 03:12 PM Last Post: r.ave |
| Alu thick core radiator fitment | Gtsi-R | 5 | 5,421 |
01-26-2022 01:28 PM Last Post: Gtsi-R |
| Clutch and brake cylinders | MIGGZFSU | 4 | 7,555 |
10-14-2017 07:52 PM Last Post: MIGGZFSU |
| Brake advice - master cylinder | mannix20vt | 12 | 19,306 |
| Correct connection brake master cylinder? | bozu | 5 | 9,702 |
