Centre Propshaft Bearing - How much play is too much ?
10-17-2005, 05:41 PM
Damn,
lots of questions I've been asking today - sorry folks.
Whilst my car was up on the ramp on saturday I took a general look under the car to see how it was holding out. I've got a front oil seal dead on the engine that is weeping a bit but nothing too serious.
The other thing I checked over was the propshaft. The one on my car is a 2-piece item that has a bearing carrier in the middle that bolts up the the tunnel. If I grab the prop near the bearing carrier there seems to be quite a bit of play (maybe 5mm). This kinda suggests to me that the bearing has collapsed.
Next time somebody has there car on a ramp could you see how much play is in yours ?
Regards Ian.
[Image: AEU86 AE86 - Centre Propshaft Bearing - ...too much ?]
10-17-2005, 07:22 PM
Don't worry about it.
If you care or it starts flopping around, get a custom 1 piece prop to rid your car of the gay centre bearing. They are cheap.
10-17-2005, 07:28 PM
Good to know brother william. You always come to the rescue.
Regards Ian.
10-17-2005, 08:53 PM
Unless you feel any vibration in the tunnel under hard acceleration or at cruising speed divna worry!
Like bro will says when it giives up go for a 1 piece prop (easy to make up)
  AE86 Driveshaft too long? [SOLVED] MyCrazyGarage 12 12,900 07-28-2022 10:48 PM
  Can you convert your 86 back too the original state? gh0st 7 5,863 04-25-2022 04:25 PM
Last Post: gh0st
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 9,945 07-31-2019 11:28 AM
  4age hitting gas too quick means engine stalls - what is the issue? Ryo 20 37,658 06-27-2018 11:15 PM
Last Post: Ryo
  20v mains & big end bearing izanagi 9 13,605 12-26-2016 12:42 PM
Last Post: pack
