Brake Bias Questions
11-21-2018, 06:42 PM
Hi Guys
![]() I have a predicament. I'm running FD3s Calipers on the front with Mini Cooper S Discs but standard AE86 discs on the back. I was planning on running a high Mu (Project Mu HC+) pad on the back that bites from cold (as I'll be using it for drifting) but I also plan on doing the odd track day in it, so need a pretty good pad up front. Front tyres will always be a Group 1B/S tyre so tyre grip isn't really a concern. My concern is, if I go for the same pad front/back, it might be too aggressive on the front for track (helps to pivot the rear if drifting though). So, I thought of my options. A - Run the same pads front/back but put in a Bias adjuster. B - Run slightly less bitey (Ferrodo DS2500) pads on the front than the back to balance out the braking a bit. C - Run slightly less bitey pads on the front than the back to balance out the braking a bit BUT with a brake bias adjuster too. Any experience would be really handy ![]() Many Thanks, Matt |
| Messages In This Thread |
Brake Bias Questions - mad.matt - 11-21-2018 06:42 PM
RE: Brake Bias Questions - Project D - 11-21-2018, 11:19 PM
RE: Brake Bias Questions - totta Crolla - 11-22-2018, 10:06 AM
RE: Brake Bias Questions - mad.matt - 11-22-2018, 07:10 PM
RE: Brake Bias Questions - totta Crolla - 11-22-2018, 07:46 PM
RE: Brake Bias Questions - mad.matt - 11-23-2018, 01:25 PM
RE: Brake Bias Questions - pack - 12-06-2018, 01:22 PM
RE: Brake Bias Questions - totta Crolla - 12-07-2018, 11:09 AM
RE: Brake Bias Questions - Dave W - 12-08-2018, 02:50 PM
RE: Brake Bias Questions - Rascal21 - 01-02-2019, 04:17 PM
RE: Brake Bias Questions - mad.matt - 01-03-2019, 04:54 AM
| 20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 7,277 |
| Windscreen stoopid(?) questions.... | Mylesmck | 7 | 3,752 |
| wider rear axle,track width,suspension questions | ditn | 6 | 12,061 |
| Suspension questions | leon205gti | 17 | 19,816 |
| Brake questions | d3nso | 12 | 18,819 |
01-20-2016 01:06 PM Last Post: pack |
