Ball joint removal with arm attached??
05-06-2010, 03:42 AM
What is the best way to remove the ball joints without unbolting the control arm?
05-06-2010, 04:08 AM
I wouldnt think it possible. It needs to be pressed out.
05-06-2010, 04:44 AM
I saw this, not sure if it would work on the corolla http://www.youtube.com/watch?v=ISY8bGof3bQ
I guess it is not a big deal to remove the arm. Should do the bushings anyway.
  STL file for the early spec Levin headlight ball joint plastic clip DaLanZhu 2 555 04-26-2025 03:24 PM
Last Post: DaLanZhu
  Rear arm length totta Crolla 7 1,813 06-05-2024 08:53 AM
Last Post: totta Crolla
  Power Steering Removal 20valver 2 1,204 05-19-2024 06:48 PM
Last Post: 20valver
  4AGE cylinder head plug removal Ivan141 5 2,664 09-30-2023 09:47 PM
  Sill removal totta Crolla 3 2,436 09-14-2022 06:30 PM
