4age 16v oem ecu rev limiter research
06-20-2015, 07:08 PM
i know the old 1983 zenki ecu's revved to about 8200 rpm before hitting the limiter. Though I wonder what use you have for that. even with my different cams max power was reached before 7k.
About Ron, he did a lot of custom work to the engine. Fabricated the inlet and everything himself. He did calculate everything in the engine resulting in to that massive power amount. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
06-21-2015, 03:35 PM
Freedom ecu board into a stock casing might be worth considering. You'd have total control over everything but it would still hook up to the original loom / connectors.
06-21-2015, 04:02 PM
Freedom ecu would be a great choice
unfortunately i think its Japanese only |
06-21-2015, 04:12 PM
haven't made any measurements but a MS would probably fit too
AE86 ex-daily |
06-21-2015, 05:45 PM
You should consider a JDM N1 Spec ECU map
06-21-2015, 09:15 PM
And an Apexi ?
06-21-2015, 10:12 PM
Any ECU will do, as long as it uses OEM connector and wiring.
It doesn't have to be in OEM case. If you ever get "scrutineered" they will unhook your custom ECU and put OEM. If your car starts and idles (even "rough as hell" will do) you are OK. These are Gr. N propisitions, not sure about Gr.A but it can only be same or even more liberated. Btw. I'm using VEMS in Motronic 2.x case with JPT-55 connector and complementary wiring. All taken from Alfa Romeo 155. Wired PCB to JPT-55 and made few changes to harness and 4AGE is working like a charm. Photo: https://lh6.googleusercontent.com/-3Z7L1...AG0076.jpg Btw. 2 You should rev engin above max power, so when you shift it to higher gear you are again close to max power RPM. |
06-21-2015, 10:20 PM
(06-21-2015 04:02 PM)ditn Wrote: Freedom ecu would be a great choice I can help you with this. An analogue brain in a digital World |
06-22-2015, 08:02 AM
Thanks for help everyone really helps
![]() So i think im gonna check first that it at least iddles and starts with original ecu. And then decide which other ecu to take. |
| Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 27,160 |
| Ecu for AE86 4AGE | Steller Engineering | 6 | 9,145 |
03-10-2021 11:06 PM Last Post: Ivan141 |
| 4AGE 16V engine overheat when at high speed | chenfon | 32 | 39,267 |
| 4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 12,255 |
| extracted freedom ecu 16v ignition map | ditn | 7 | 13,052 |
