4a-ge Oil Pressure Sensor Gauge, i need info
10-26-2011, 10:50 AM
Ivan141 Wrote:Its in the middle of that doorbell like thing. You just slide the connector over it. This wire commonly lets loose, you might want to tighten the connector with a screwdriver or something like that before refitting the wire.The connector itself slide in one side, right? OK, now I understand, I thought that was a connector to plug in the cable thanks guys! |
| Messages In This Thread |
4a-ge Oil Pressure Sensor Gauge, i need info - Mattolo - 10-24-2011, 12:51 PM
Re: 4a-ge Oil Pressure Sensor Gauge, i need info - Project D - 10-24-2011, 06:05 PM
Re: 4a-ge Oil Pressure Sensor Gauge, i need info - Mattolo - 10-24-2011, 06:30 PM
Re: 4a-ge Oil Pressure Sensor Gauge, i need info - Project D - 10-24-2011, 09:59 PM
[] - Mattolo - 10-26-2011 10:50 AM
| map sensor cheating? | fdsjakl890 | 8 | 2,412 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| EUDM gauge cluster | banpei | 22 | 11,059 |
08-15-2023 10:48 PM Last Post: banpei |
| Lambda sensor wiring | sam3007 | 10 | 7,827 |
| Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 24,907 |
| Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 10,428 |
12-06-2017 06:48 PM Last Post: Bean |
