4a-ge Oil Pressure Sensor Gauge, i need info
10-24-2011, 09:59 PM
Re: 4a-ge Oil Pressure Sensor Gauge, i need info
Mattolo Wrote:For type I mean: exists more types of Oil Switch Pressure, for example I have two different that I used for another car prepped for racing.
If you ask about original part on the 4AG:
if you have "analog" dash it's a round bulb
83520‑14022
[Image: AEU86 AE86 - Re: 4a-ge Oil Pressure Sens... need info]
If you have digital gauge (but you don't) it's a switch.
If you ask if every sensor in the world are the same: NO
You can't take a sensor from another car or brand and expect it work like the toyota one.
Mattolo Wrote:It's near the oil filter, right?
Now it's was replacement with a bolt -_-
Yes but not really close. It's more closer to the oil pump.
Look your own picture:
See under the bracket of the Power steering pump ?
just after (between oil filter and oil pressure sensor) you have a bolt, but it's NORMAL, this is not the place of the oil sensor Wink
Mattolo Wrote:I think that the mechanic broke the switch and replaced it without telling me.
Only some time later I realized that the oil pressure indicator don't work, because I keep the Ae86 in garage stops for months; the cable of oil pressure indicator was unplugged and I found a bolt in place of switch.
Can you take a picture of the side of your engine ?
That way it will be easier to tell you if the sensor is missing or not Wink
Messages In This Thread
[] - Project D - 10-24-2011, 01:43 PM
[] - Mattolo - 10-24-2011, 03:29 PM
Re: 4a-ge Oil Pressure Sensor Gauge, i need info - Project D - 10-24-2011 09:59 PM
[] - Mattolo - 10-25-2011, 11:41 AM
[] - Project D - 10-25-2011, 03:37 PM
[] - Mattolo - 10-25-2011, 05:42 PM
[] - Mattolo - 10-25-2011, 05:56 PM
[] - Ivan141 - 10-25-2011, 09:28 PM
[] - Mattolo - 10-26-2011, 10:50 AM
  EUDM gauge cluster banpei 22 6,361 08-15-2023 10:48 PM
  Lambda sensor wiring sam3007 10 5,353 05-23-2022 10:00 PM
Last Post: The Doctor
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 22,331 08-19-2018 12:08 PM
Last Post: AlexKTM
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 8,417 12-06-2017 06:48 PM
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 5,239 11-05-2016 01:34 AM
Last Post: oldeskewltoy
