4a-ge Oil Pressure Sensor Gauge, i need info
10-24-2011, 06:30 PM
Re: 4a-ge Oil Pressure Sensor Gauge, i need info
Project D Wrote:
Mattolo Wrote:Hi, i need to know the type of Oil pressure sensor bulb for my 4a-ge.
Mattolo Wrote:no i'm looking for this:
83530 SWITCH ASSY, OIL PRESSURE (FOR ENGINE)
Switch is NOT a sensor !!! It just tell you when you have oil pressure problem. Basically you have that when you don't have oil pressure gauge (Digital dash don't have gauge, so they have switch Wink )
Mattolo Wrote:I think that bulb it's common, any idea?
Mine was stolen by a mechanical -_-
Every 4AG have the sensor mentioned earlier (except AE86 with digital dash)
What I don't understand is how someone can steal it since it's under the power steering pump !
(and I can see it on your own picture HERE
Also what do you mean by "type" ?!
Excuse me, I'm confused about exact term in english.
For type I mean: exists more types of Oil Switch Pressure, for example I have two different that I used for another car prepped for racing.
It's near the oil filter, right?
Now it's was replacement with a bolt -_-
I think that the mechanic broke the switch and replaced it without telling me.
Only some time later I realized that the oil pressure indicator don't work, because I keep the Ae86 in garage stops for months; the cable of oil pressure indicator was unplugged and I found a bolt in place of switch.
Messages In This Thread
[] - Project D - 10-24-2011, 01:43 PM
[] - Mattolo - 10-24-2011, 03:29 PM
Re: 4a-ge Oil Pressure Sensor Gauge, i need info - Mattolo - 10-24-2011 06:30 PM
[] - Mattolo - 10-25-2011, 11:41 AM
[] - Project D - 10-25-2011, 03:37 PM
[] - Mattolo - 10-25-2011, 05:42 PM
[] - Mattolo - 10-25-2011, 05:56 PM
[] - Ivan141 - 10-25-2011, 09:28 PM
[] - Mattolo - 10-26-2011, 10:50 AM
  EUDM gauge cluster banpei 22 6,436 08-15-2023 10:48 PM
  Lambda sensor wiring sam3007 10 5,377 05-23-2022 10:00 PM
Last Post: The Doctor
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 22,379 08-19-2018 12:08 PM
Last Post: AlexKTM
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 8,427 12-06-2017 06:48 PM
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 5,280 11-05-2016 01:34 AM
