4AGE crankcase gas and oil pressure too high, sprinking oil
09-30-2011, 11:39 AM
I agree with jondee (that rhymes
![]() Sounds like you've lost compression on a piston, probably stuck/broken piston rings. If the engine still idles it's probably not too far gone yet. The nr.4 cylinder is usually the first to go... Get the compression checked as jondee suggested, I would advise not driving it too much until you know what's wrong. FABRICA MI DIEM, PVNC! |
Messages In This Thread |
4AGE crankcase gas and oil pressure too high, sprinking oil - demogun - 09-30-2011, 09:48 AM
[] - Ivan141 - 09-30-2011 11:39 AM
High-beam warning lamp | Mylesmck | 4 | 1,860 |
Engine stress at high speeds | gh0st | 6 | 3,000 |
AE86 Driveshaft too long? [SOLVED] | MyCrazyGarage | 12 | 8,580 |
07-28-2022 10:48 PM Last Post: banpei |
Can you convert your 86 back too the original state? | gh0st | 7 | 3,377 |
04-25-2022 04:25 PM Last Post: gh0st |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 24,476 |
