4AGE 16V engine overheat when at high speed
11-06-2020, 11:22 AM
RE: 4AGE 16V engine overheat when at high speed
Dear all
just to update on the my engine overheat issue. Finally have sufficient free time to dismantle the radiator and DIY overhaul service, found that the inside serious blocked and it might due to i recently had done the "scale" wash in engine cooling system with chemical, all the dirt clog at radiator.[Image: AEU86 AE86 - RE: 4AGE 16V engine overhea...high speed]
after 1 by 1 slot clear, reinstall with new thermostat and radiator hose. Test run and found no more overheat issue, now the temperature always at 1/3 of the gauge although i at high speed.
so as conclusion that all above issue is due to radiator clog. thanks allot on the ideal and suggestion from the member. love u guys. tqvm
Messages In This Thread
RE: 4AGE 16V engine overheat when at high speed - chenfon - 11-06-2020 11:22 AM
  High-beam warning lamp Mylesmck 4 1,345 07-21-2023 07:44 AM
  Engine stress at high speeds gh0st 6 2,314 08-30-2022 07:11 PM
Last Post: Power_uP
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 20,163 05-01-2021 10:09 PM
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 6,984 11-09-2020 10:51 AM
Last Post: totta Crolla
  AE86 4A-GE 16v engine harness rebuild FanIsHere 7 9,716 01-17-2020 08:04 PM
Last Post: Project D
