4AGE 16V engine overheat when at high speed
07-22-2020, 01:01 AM
RE: 4AGE 16V engine overheat when at high speed
The length of wiring outside the conduit is too short to provide sufficient
flexibility to prevent the wires failing from fatigue. After that heavy plug has jiggled around a few million times it can fail where it joins to the plug. If the cover on the wire is stripped back for a soldered join that creates a weak spot due to lack of support for the copper wire. There should have been a larger loop of cable there to spread the flexing. Even with the soft braided sheath used on the factory wiring failures can occur at the point where the wires enter the distributor. That is where the wires are subject to maximum bending as the cable flexes with the movement of the car. Rare, but it does happen. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
| High-beam warning lamp | Mylesmck | 4 | 3,479 |
07-21-2023 07:44 AM Last Post: banpei |
| Engine stress at high speeds | gh0st | 6 | 4,913 |
08-30-2022 07:11 PM Last Post: Power_uP |
| Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 25,132 |
05-01-2021 10:09 PM Last Post: Ivan141 |
| 4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 10,707 |
| AE86 4A-GE 16v engine harness rebuild | FanIsHere | 7 | 14,007 |
01-17-2020 08:04 PM Last Post: Project D |
