4AGE 16V engine overheat when at high speed
07-20-2020, 01:04 PM
RE: 4AGE 16V engine overheat when at high speed
You can pry off the back side of the yellow plug. Trim the current wire ends, and re-attached the wires to the spades. Carefully remove the old ends of the wires from the spades. Then, re-bend the prongs, on to the newly cut ends, and then add a new solder to each of the connections. Finally seal the connector plug with RTV inside the plug, before pushing the back of the connector back into place.
[good for another 25 yrs.]
Dave W
Messages In This Thread
RE: 4AGE 16V engine overheat when at high speed - Dave W - 07-20-2020 01:04 PM
  High-beam warning lamp Mylesmck 4 3,500 07-21-2023 07:44 AM
  Engine stress at high speeds gh0st 6 4,950 08-30-2022 07:11 PM
Last Post: Power_uP
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 25,157 05-01-2021 10:09 PM
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 10,757 11-09-2020 10:51 AM
Last Post: totta Crolla
  AE86 4A-GE 16v engine harness rebuild FanIsHere 7 14,026 01-17-2020 08:04 PM
Last Post: Project D
