4AGE 16V engine overheat when at high speed
06-13-2020, 12:07 AM
RE: 4AGE 16V engine overheat when at high speed
Having trouble getting my head around this ?? Retarded ignition can cause
combustion within the exhaust system and lead to a red hot header. I don't
have a problem with that. However, the cooling system picks up heat from
the block and head so fuel combusting in the exhaust would have little
effect on the amount of heat being picked up by the coolant.
Heat is a product of combustion, and the more fuel you burn the more heat
you get. So if some fuel is combusting external to the engine, by definition
there is less fuel being burned internal to the engine. Logic suggests that
this would lead to less heat entering the cooling system rather than more...
n'est-ce pas ?
Always willing to learn so quite happy to be proven wrong Smile
Cheers... jondee86
Messages In This Thread
RE: 4AGE 16V engine overheat when at high speed - jondee86 - 06-13-2020 12:07 AM
  High-beam warning lamp Mylesmck 4 3,105 07-21-2023 07:44 AM
  Engine stress at high speeds gh0st 6 4,494 08-30-2022 07:11 PM
Last Post: Power_uP
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 24,356 05-01-2021 10:09 PM
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 10,123 11-09-2020 10:51 AM
Last Post: totta Crolla
  AE86 4A-GE 16v engine harness rebuild FanIsHere 7 13,335 01-17-2020 08:04 PM
Last Post: Project D
