4AGE 16V engine overheat when at high speed
06-10-2020, 12:41 PM
RE: 4AGE 16V engine overheat when at high speed
What has been known to happen is that the return hose from the radiator can get
"collapsed" by the suction of the water pump at higher rpm. This can only happen if the hose is old and very soft, or if the hose has started to de-laminate internally. Some radiator hoses have a coiled steel spring fitted inside the hose to prevent the hose being sucked flat. But if the bottom radiator hose is very soft it may be worth while putting a new one on to see if it solves the problem. If the top hose is also very soft, maybe replace them both. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
High-beam warning lamp | Mylesmck | 4 | 2,208 |
07-21-2023 07:44 AM Last Post: banpei |
Engine stress at high speeds | gh0st | 6 | 3,357 |
08-30-2022 07:11 PM Last Post: Power_uP |
Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 22,552 |
05-01-2021 10:09 PM Last Post: Ivan141 |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 8,704 |
AE86 4A-GE 16v engine harness rebuild | FanIsHere | 7 | 11,573 |
01-17-2020 08:04 PM Last Post: Project D |
