16v oversize valve seats
09-20-2016, 05:04 PM
RE: 16v oversize valve seats
harkes Wrote:Do you know where Lyonings get their seats from?
They make them for themselves... from what I've seen they have a long tube of steel/copper that they "slice" off sections to use for seats.
(09-20-2016 04:02 PM)harkes Wrote:
(09-20-2016 12:25 PM)Bean Wrote:  Which cams do you use and what's your CR if I may ask.
Honestly I am not sure. I bought them second hand as Schrick 288 but I dont think they are. More likely 300 (in Toda terms). I have spend hours investigating the numbers on them with no result. My CR is 11.3.
[Image: AEU86 AE86 - RE: 16v oversize valve seats]
those look like "big" cams... they appear to be larger then 8.4mm... (just guessing....) Do you know how close they come to the edge of the bucket cylinder casting??
This is the 272/235 - 9.4mm cam - note it is VERY close, but the bucket has not had to be modified for clearance
Btw.... I assume you are still using the piston/rod combo? Then you don't have to worry about valve interference if you decided to go OS....
Dan -
Messages In This Thread
16v oversize valve seats - harkes - 09-19-2016, 07:43 AM
RE: 16v oversize valve seats - jondee86 - 09-19-2016, 09:40 AM
RE: 16v oversize valve seats - harkes - 09-19-2016, 10:52 AM
RE: 16v oversize valve seats - harkes - 09-20-2016, 03:11 AM
RE: 16v oversize valve seats - Ivan141 - 09-20-2016, 09:42 AM
RE: 16v oversize valve seats - harkes - 09-20-2016, 10:14 AM
RE: 16v oversize valve seats - Bean - 09-20-2016, 12:25 PM
RE: 16v oversize valve seats - harkes - 09-20-2016, 04:02 PM
RE: 16v oversize valve seats - oldeskewltoy - 09-20-2016 05:04 PM
  4A-GE valve shim disintegrated DaLanZhu 2 2,257 04-30-2025 12:54 PM
Last Post: DaLanZhu
  Squeaky seats - any tips? decryphe 2 2,706 10-18-2023 10:13 PM
Last Post: Power_uP
  4AGE Valve Buckets Scored Steller Engineering 2 2,370 10-06-2023 05:34 PM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 3,526 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 4,080 05-25-2022 10:24 PM
