14x7 Celica Supra wheels and spacers?
03-09-2011, 01:18 AM
14x7 Celica Supra wheels and rear spacers?
What size spacer do I need in the back to fit my wheels resonably flush or a tiny bit poked? I have 195/55-14's on there now, so there is an ever-so-slight stretch, but definitely not square fitment.
03-09-2011, 01:42 AM
I beleive they will fit out of the box, no spacers needed.
03-09-2011, 07:30 AM
I know they will, but they're sunk in... which is why I said I wnted a flush or slightly poke fitment. That's gonna mean using a spacer but I don't want to go TOO big.
03-09-2011, 09:09 AM
They seat flush alright.
The offset is 8, so 5 mm plain spacer will take you to +3 which is fine.
A.
[Image: AEU86 AE86 - 14x7 Celica Supra wheels and spacers?] http://www.jdmbits.com
03-09-2011, 07:27 PM
Ahhh I see the offset is +8. Now that I know this, I think I'll actually go with an 8mm spacer and give myself -/+0, having seen what zero offset and 7" wide looks like on these cars. Thanks for the info!
03-09-2011, 09:29 PM
Arro Wrote:Ahhh I see the offset is +8. Now that I know this, I think I'll actually go with an 8mm spacer and give myself -/+0, having seen what zero offset and 7" wide looks like on these cars. Thanks for the info!
You cant do that!
You either go with 5 mm plain spacer which allows the nuts to bolt properly, or then move up to 10 mm with their own studs. They are more expensive though.
A.
03-09-2011, 10:16 PM
Here are some pics from my car with 185/60/14 fitted in celica supra rims:
without spacers:
with 25mm spacers:
03-10-2011, 10:42 AM
nmwisima: I would have run longer studs Wink Don't think I'll go that route now...
Rosedrift: I assume those 25mm spacers are hub-centric pieces w/ their own studs and short inner nuts to go on the factory studs... also I assume you had to grind down the factory studs to clear the wheels... right?
Your fitment is exactly what I want! Thumbs up! Although keep in mind I have 195/55-14's on those same wheels... so maybe 25mm is a tad bit too much, and 20mm is gonna be better. I need to search and see what size options for 4x114.3 Toyota hub spacers are avail. in my region.
03-10-2011, 12:34 PM
YES hubcentric with their own studs, and NO i didn't had to grind down the factory studs.That's why I went to 25mm, with 20mm you'll probably need it. The only thing I had to do is to bend a little the fenders from inside to avoid the contact with tyres.
I bought my spacers from pass racing (california) Tongue
  4age fuel rail spacers kpretro84 5 9,490 03-16-2013 08:30 PM
  celica ra40 brake upgrade geoffersmaher 8 11,667 12-21-2009 10:52 PM
Last Post: geoffersmaher
  4AGE ECU CELICA-CARINA-CORONA COUPE tolisspi 11 14,117 01-10-2009 09:39 PM
  just bought sum celica supras an im on a budget need tires?? truebluegallo 4 5,766 10-28-2008 10:21 PM
  DIY: My Celica-Supra (MA45/46/47) diff swap & info. assassin10000 17 30,753 07-15-2008 11:47 PM
Last Post: assassin10000
