| Author |
Message |
totta Crolla Takumi
Posted: Sat Aug 16, 2008 8:48 pm Post subject: Underbucket shims |
Anyone have a clue what to use ?
I have seen a 'top hat' type used that sits on the valve stem and I know TRD do a spring retainer that uses a flat 9.5mm shim that fits in the top. I think the TRD ones use non standard collets (keepers) also. Any other issues with the TRD type ? thanks tc
_________________ "accidents are rare but you're a long time dead"
| Back to top |
robokill Bunta
Joined: 07 Sep 2004 Posts: 2197 Location: Amsterdam // The Netherlands
Posted: Sat Aug 16, 2008 9:10 pm Post subject: |
Yaris ones. Yaris (vitz?) has the same size. Its well known in japan and also found on club4ag. I am building an engine which also has it. Just buy the cams. Measure with the original buckets than buy one yaris. Measure what you need and order form toyota.
_________________ "08 Honda Civic Hybrid
KIS it
Keep It Sideways
| Back to top |
totta Crolla Takumi
Posted: Sat Aug 16, 2008 10:09 pm Post subject: |
Thanks for the reply. I should have made it clear that I already have the underbucket cam followers, just need to sort the shims now
| Back to top |
F0Bman Takumi
Posted: Wed Aug 27, 2008 5:37 am Post subject: |
Consider using the Yaris under bucket shims, these are one piece and are much lighter.
_________________ Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
| Back to top |
eight-six Ryousuke
Joined: 23 Aug 2005 Posts: 149 Location: South West UK
Posted: Wed Aug 27, 2008 10:32 am Post subject: |
Totta - The set up you have described sounds identical to the shim/bucket set up found on the late spec 3sgte (and possibly other engines)
Its an under bucket arrangment with a small shim that sits in the spring retainer recess under the bucket - the shim is about 10mm across or there abouts from memory.
The shims can be found on 1994 onwards SW20 turbo or a ST205 GT4.
Sounds like you have confirmed what I stated a whle back that the under bucket arrangement on the late 3SGTE will also fit the 4AGE head.
Your looking at about £40 for a full set of shims for the head - Toyota can supply them in every size but you will need to get 1 first so you can work out the tolerances and what you need for the rest of the 16 valves.
I will see if I have any spares kicking around in the garage from the last gte rebuild i did.
_________________
www.eight-six.co.uk - UK AE86 Forum
http://www.phpbber.com/phpbb/index.php?mforum=wwweightsixcouk
| Back to top |
F0Bman Takumi
Posted: Mon Sep 22, 2008 4:28 am Post subject: |
Try contacting friends on this board to get you the shim sizes you need for your head adjustment.
| Back to top |
