TODA Pistons
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
tolisspi
Takumi
PostPosted: Tue Sep 02, 2008 10:00 pm    Post subject: TODA Pistons Reply with quote
I want to change the pistons. I found some TODA's pistons.
http://todaracingusa.com/category?section=produ...;cid=25&id=85
I want to buy the 82mm and 20pin. Is the compression ratio like a standard 11,3:1 with oem headgasket? If i want low it?
What is the meaning "over sized"?
_________________
**COROLLA EE80 - 4AGE 124HP**
Back to top
F0Bman
Takumi
PostPosted: Wed Sep 03, 2008 5:34 am    Post subject: Reply with quote
Oversized means that the bore size is larger than stock. Lowering the compression is by usingh a thicker headgasket.
_________________
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
Back to top
tolisspi
Takumi
PostPosted: Wed Sep 03, 2008 4:00 pm    Post subject: Reply with quote
So the TODA's pistons have standard compression. And i can adjust the compression with a headgasket?
But the wiseco pistons have compression ratio for 10,3:1 to 11,8:1.
_________________
Back to top
Ivan141
Moderator
PostPosted: Wed Sep 03, 2008 9:04 pm    Post subject: Reply with quote
No the toda pistons have 11:1 and higher compression ratio's.
But the whole point of these pistons is the higher compression.
You could lower it a bit by installing a thicker headgasket, but then why not just buy a thinner headgasket for your current engine and accomplish the same thing?
_________________
'81 poor guy with a money-pit
Back to top
tolisspi
Takumi
PostPosted: Wed Sep 03, 2008 9:30 pm    Post subject: Reply with quote
i have problem with some rods in the bottom end. And i rebuilt a 4agze bottom end with high compression pistons
_________________
Back to top
F0Bman
Takumi
PostPosted: Mon Sep 22, 2008 4:25 am    Post subject: Reply with quote
The reason to use such nice pistons is added protection against detonation and for lighter weight. Plus when running higher lift cams it will reduce your dynamic compression.
_________________
Back to top
tolisspi
Takumi
PostPosted: Mon Sep 22, 2008 7:07 pm    Post subject: Reply with quote
so is it good to reduce the dynamic compression?
_________________
Back to top
Project D
Wataru
1987 Toyota Corolla AE86 (late EU)
PostPosted: Tue Sep 23, 2008 1:18 am    Post subject: Reply with quote
no Very Happy
_________________
Back to top
tolisspi
Takumi
PostPosted: Sat Oct 04, 2008 9:25 pm    Post subject: Reply with quote
So i bought toda 82mm and 20 pin withoem headgasket the compression ll be 11,3
_________________
Back to top
BOOMEX
Ryousuke
PostPosted: Mon Oct 06, 2008 6:11 am    Post subject: Reply with quote
I'm quite newb in those things but the dynamic compression isn't it reduce buy hi-duration cams hier than hi-lift cams...?
_________________
BURN THE RUBER NOT YOUR SOUL!
Back to top
View user's profile Send private message Visit poster's website MSN Messenger
Project D
Wataru
PostPosted: Mon Oct 06, 2008 9:13 am    Post subject: Reply with quote
yes you're right boomex
it's the duration and not the lift
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
