Standalone for AE86 4age to AE82 4age
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
tolisspi
Takumi
PostPosted: Tue Sep 02, 2008 9:59 pm    Post subject: Standalone for AE86 4age to AE82 4age Reply with quote
I have some questions.
Can i use a standalone kit for AE86 on my AE82 ECU? Have i change something? ll it Work?
_________________
**COROLLA EE80 - 4AGE 124HP**
Back to top
F0Bman
Takumi
PostPosted: Wed Sep 03, 2008 5:35 am    Post subject: Reply with quote
Yes you can use a standalone unit from the AE86 to be used on the AE82. But the pins are different on the ECU, which means you have to get connectors.
_________________
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
Back to top
tolisspi
Takumi
PostPosted: Wed Sep 03, 2008 3:56 pm    Post subject: Reply with quote
What do you mean "the pins are differents"? My ecu has 10-18-14 pins. Exactly, my ecu is from celica-corona coupe-carina 4age 85-87. Here is a pic
AE86 : Technical > Standalone for AE86 4age to AE82 4age
but ihave an ecu from AE82 European edition like that
Can i use a map from AE86 to my car?
Thanks a lot mate
im waiting your answer.
_________________
Back to top
Chrisso
Iketani
PostPosted: Fri Sep 05, 2008 9:10 am    Post subject: Reply with quote
Have a look at the plugs of the AE82 ECU, it should be the same 10-18-14 configuration. The only possible difference will be in the pin functions. By that I mean that pin 1-10 in your AE86 ECU might have a different function to pin 1-10 in the AE82 ECU. Appart from finding the wiring diagrams for each one, you can take the covers off and have a look at the circuit boards. There should be a designation for each pin. If these all match, then plug and play. If not, then find your wiring diagrams and determine what each pin does.
Back to top
tolisspi
Takumi
PostPosted: Fri Sep 05, 2008 10:11 am    Post subject: Reply with quote
Thanks a lot mate but i dont have an ecu of AE86. maybe i can check it with wiring diagrams of ae86'w ecu and ae82'w ecu.
_________________
Back to top
tolisspi
Takumi
PostPosted: Tue Sep 30, 2008 11:25 pm    Post subject: Reply with quote
Which brand do you think that i can use? standalone or piggyback? My project includes cam 272 10,3 lift, pistons 82mm
_________________
Back to top
Chrisso
Iketani
PostPosted: Wed Oct 01, 2008 3:51 am    Post subject: Reply with quote
You've got me a bit turned around here. So, you've got an AE86 wiring loom in there at the moment and you are a) changing engines, or b) changing computers?
It sounds like you're changing computers, as engine is just plug it up and go. So if you're looking for a standalone ECU then it doesn't matter. Just find one that you're comfortable with, considerations will be:
1)Price
2)Functions
3)Access to a tuner you trust
Just about all brands should be able to provide a linking cable to match your current loom to the computer. I would suggest a standalone over a piggyback.
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
