rear suspension setup
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Track related
Author Message
legend
Wataru
PostPosted: Fri Mar 31, 2006 9:23 pm    Post subject: rear suspension setup Reply with quote
Need some info on the rear suspension setup.
In the front im going with koni adjustabe shortshocks for the AE92 and some coilovers theres no problem there but id like some info on the rear supension. Cause I live in sweden the AE86 was never sold here so I need some tips for shocks that fit the rear and some tips how to get coilovers at the rea setup. has anybody doen this before and if they have hgow did they do it. The car is for track and drift only so dont care about comfort.
thanks alot
Back to top
Mux213
Site Admin
PostPosted: Fri Mar 31, 2006 11:42 pm    Post subject: Reply with quote
Hey Legend,
Well depending on how adjustable you want your car, and how low you are going to make it (with ae92 shocks I'm assuming you'll lower it atleast a few cms) you can go for instance for TRD springs in the rear and short stroke shocks. Then just adjust your front coilovers to match.
If you find a good spring supplier let me know, I'm still looking for stiff rear springs that don't lower the car to much:)
If you really want to go coilover on the rears that are adjustable then there aren't to many options and you'll have to do some changes to the rear. Paradise racing has a good set for sale, so does T3. However I personally don't like the coil over setups unless the rear axle is modified, for some reason I don't think the mounts will last with serious abuse:)
_________________
No more hachi Sad
Back to top
jamiemirror
Bunta
PostPosted: Sun Apr 02, 2006 9:45 am    Post subject: Reply with quote
Fiat Argenta front shocks can be used as rear on AE86 (-30mm). Minor rework is needed.
Back to top
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger MSN Messenger
Mux213
Site Admin
PostPosted: Sun Apr 02, 2006 12:14 pm    Post subject: Reply with quote
Jamie, but those can't be very still shocks?
_________________
No more hachi Sad
Back to top
jamiemirror
Bunta
PostPosted: Sun Apr 02, 2006 9:23 pm    Post subject: Reply with quote
"very still" - I can't understand (sorry English is not my native language) Blonde question
You can buy gas or some performance Argenta shocks (mine are gas Monroes)- the bonus is just that they are 30mm shorter than AE86 ones (that's why I lowered my front struts with 30 mm using 40mm shorter AE92 shocks + 10mm inserts).
Back to top
Ivan141
Moderator
PostPosted: Sun Apr 02, 2006 10:46 pm    Post subject: Reply with quote
Mux probably made a typo...it should be "very stiff". I do know that americans use some camaro rear shocks, those are also a bit shorter. The trouble for us is that we never got much camaro's over here so those shocks arent going to be easy to find, and I've never seen a fiat argenta in holland. If it was ever sold here it was long ago and we end up with the same problem...it's hard to find proper parts.
_________________
'81 poor guy with a money-pit
Back to top
Mux213
Site Admin
PostPosted: Sun Apr 02, 2006 11:15 pm    Post subject: Reply with quote
oops, typo indeed:) hehehe ment stiff:)
_________________
No more hachi Sad
Back to top
legend
Wataru
PostPosted: Mon Apr 03, 2006 8:23 pm    Post subject: Reply with quote
how is the AE92 shocks in the back are they useable on the AE86.
im gonna lower te car 60 mm that is whats planned anyways but still a question wich shocks and wich springs to use anybody know of a car with some specs on it so I can see what hes got
Back to top
Ivan141
Moderator
PostPosted: Tue Apr 04, 2006 7:42 am    Post subject: Reply with quote
AE92 shocks only fit the front. I think I also read about some older supra shocks that will fit the rear, but I cant recall exactly which type.
_________________
Back to top
legend
Wataru
PostPosted: Tue Apr 04, 2006 7:53 pm    Post subject: Reply with quote
guess I have to try what fits then
Back to top
Denmark
Takumi
PostPosted: Tue Apr 04, 2006 8:44 pm    Post subject: Reply with quote
I also think i read somewere that some hilux ones worked as shortstroke.
I will looke into it
/Skassa
_________________
"""www.turbotoys.dk"""
Back to top
El_Camino
Takumi
1983 Toyota Corolla AE86 (early Levin)
PostPosted: Tue Apr 04, 2006 10:16 pm    Post subject: Reply with quote
In the front I am with TA22 shocks (I believe). They are pretty easy to find in eBay and veeery cheap, as nobody knows how perfect they fit on the hachi. As they are a bit stiffer the car handles also pretty ok.
For the rear shocks I have this list. Of course I havent tried all those options, so if trying please try to collect some more information - check if the Koni numbers are equal or so...
DAIHATSU :
CHARMANT (A)
1.3 (A35) (48 kW ; 11/1981 - 07/1987)
1.5 (A55) (09/1981 - 07/1983)
1.6 (A45) (55 kW ; 12/1981 - 09/1984)
1.6 (A60) (57 kW ; 09/1985 - 07/1987)
1.6 (A60) (60 kW ; 05/1986 - 07/1987)
1.6 (A60) (61 kW ; 08/1983 - 07/1987)
TOYOTA :
CARINA (TA1_)
1.4 (TA/RA10,30) (02/1970 - 09/1977)
1.6 (55 kW ; 02/1976 - 03/1978)
1.6 (TA12) (58 kW ; 05/1973 - 03/1978)
1.6 (63 kW ; 10/1975 - 03/1978)
1.8 (TA/RA10,30) (02/1970 - 09/1977)
2.0 (TA/RA10,30) (02/1970 - 09/1977)
CELICA (TA/RA 2/3)
1.4 (TA,RA 20) (12/1970 - 09/1975)
2.0 (TA,RA 20) (12/1970 - 09/1975)
2.0 (TA/RA 23/28/35) (10/1975 - 07/1977)
CELICA (TA2)
1.6 LT (TA2) (55 kW ; 02/1976 - 03/1978)
1.6 LT (TA22) (58 kW ; 05/1973 - 03/1978)
1.6 ST (TA2, TA22) (63 kW ; 05/1973 - 03/1978)
1.6 GT (TA2, TA22) (79 kW ; 12/1974 - 03/1978)
COROLLA (_E7_)
1.3 (KE70) (44 kW ; 09/1979 - 06/1983)
1.3 (KE70) (48 kW ; 02/1982 - 06/1983)
1.6 (TE71) (55 kW ; 10/1982 - 09/1983)
1.8 D (CE70) (43 kW ; 01/1983 - 09/1983)
COROLLA Liftback (_E7_)
1.3 (KE70) (44 kW ; 09/1979 - 01/1982)
1.3 (KE70) (48 kW ; 02/1982 - 05/1983)
1.6 (TE71) (54 kW ; 09/1979 - 05/1983)
1.6 (TE71) (55 kW ; 09/1979 - 05/1983)
1.6 (TE71) (63 kW ; 09/1979 - 05/1983)
1.6 GT (TE71) (81 kW ; 05/1980 - 09/1983)
1.8 (TE72) (57 kW ; 09/1979 - 05/1982)
1.8 D (CE70) (48 kW ; 01/1983 - 09/1983)
COROLLA Coupe (AE86)
1.6 (AE 86) (08/1983 - 05/1985)
1.6 SR 16V (57 kW ; 05/1983 - 04/1987)
1.6 16V (85 kW ; 12/1985 - 04/1987)
1.6 GT 16V (AE86) (91 kW ; 08/1983 - 07/1987)
_________________
"..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984
Back to top
View user's profile Send private message Visit poster's website
filh
Takumi
PostPosted: Wed Apr 05, 2006 1:10 am    Post subject: Reply with quote
and about rear springs ? What are you using? I broke springs last year
and I don't know what to use . Stocks are a little too soft and too high( front springs lowered).The broken springs wire was 12mm(dia).
Any idea, considering it's for rallye purpose , and I don't need progressive item?
filh
_________________
Filh
Save the RWD cars
Back to top
El_Camino
Takumi
PostPosted: Wed Apr 05, 2006 1:34 am    Post subject: Reply with quote
My rear springs are very soft too. I guess they havent being changed for 23 years now, so I'm also looking for option for them. The cheapest way is to get them out and to try to find similar at the scrab yards. There are some from Volvo from the early 80s that will do fit... but personaly I will not go for used or different spring.
I like rally driving too, and so far I see (thanks to the old soft springs:)) - softer springs on the back is the right setup. On tarmak with 195/60/14 the car ist very easy to be fully trottled in the turns, without loosing traction.
You could check the threads in the forum for opinions about springs. They are some very helpfull ones ...
_________________
Back to top
jamiemirror
Bunta
PostPosted: Wed Apr 05, 2006 10:26 am    Post subject: Reply with quote
filh
Try Nissan Primera P10 rear springs.
Back to top
filh
Takumi
PostPosted: Wed Apr 05, 2006 11:03 pm    Post subject: Reply with quote
absolutly, soft stock rear springs are the good way for optimal grip , but in
situation like jumping , or in bad gravel , stock springs don't resist !
That's why I use 1mm(dia) more than the 11mm stock springs.
I don't know if there are solutions like Eibach etc .
I had mine manufactured , but it's expensive : about 150€ for 2 springs ..
I'll check for Nissan springs properties .
Filh
_________________
Filh
Save the RWD cars
Back to top
banpei
Site Admin
1982 Toyota Carina
PostPosted: Sat Apr 08, 2006 8:32 am    Post subject: Reply with quote
They fit? Blonde question
_________________
*** http://shop.aeu86.org - shop at aeu86 dot org - Sint Vitusstraat 78, 1211PK Hilversum, NL ***
Back to top
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger Skype Name
El_Camino
Takumi
PostPosted: Sat Apr 08, 2006 8:59 am    Post subject: Reply with quote
From what I know about Eibach - they are shorter too.
Another question - when you lower the car (even with only 40mm) isnt it necessary to adjust the panhard rod aswell?
By my understanding the car falls down, so the panhard rod is pushing more to the left and the rear axle is not anymore centered by it.
_________________
Back to top
jamiemirror
Bunta
PostPosted: Sat Apr 08, 2006 10:11 am    Post subject: Reply with quote
Yes. The only "problem" is that I have H&R brand sport springs for P10 so I can't say for sure what is the height of OEM P10 springs.
Back to top
banpei
Site Admin
1982 Toyota Carina
PostPosted: Sat Apr 08, 2006 10:23 am    Post subject: Reply with quote
Ah, I see. I thought you meant oem springs. Wink
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Track related All times are GMT + 2 Hours
Page 1 of 1
Jump to:
You cannot attach files in this forum
