| Author |
Message |
Allexz Ryousuke
Posted: Tue Apr 29, 2008 9:07 pm Post subject: Oil leaking from top but its not broken ??? |
i have started the engine now and took it for a spin.. i have noticed that oil are leaking somewhere... between the top and the cylinder block.. can not see exactly but someone maybe knows of this.. Thanks!
_________________ Donīt Think About The Past,
Live In The Present And
Dream About Tomorrow
| Back to top |
Ivan141 Moderator
Joined: 06 Sep 2004 Posts: 4695 Location: Netherlands Z-H
Posted: Tue Apr 29, 2008 9:52 pm Post subject: |
Distributor oil seal
Valve cover gasket
Camshaft seals (not likely)
Those are the obvious things to look out for.
'81 poor guy with a money-pit
| Back to top |
F0Bman Ryousuke
Posted: Fri May 09, 2008 7:46 pm Post subject: |
Make sure you're valve cover grommets and valve cover seals are still good. When using new valve cover seals you have to use the Toyota FIPG on 2 spots for each valve cover seal.
_________________ Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
| Back to top |
nikos_trd Ryousuke
Joined: 28 Feb 2006 Posts: 171 Location: athens.greece
Posted: Fri May 09, 2008 7:48 pm Post subject: |
camshafts seals.i have the same problem.
| Back to top |
