nzae86's trdn2 Race Car Project 2
Goto page 1, 2, 3, 4  Next
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Projects
Author Message
nzae86
Wataru
PostPosted: Tue Jan 01, 2008 10:01 am    Post subject: nzae86's trdn2 Race Car Project 2 Reply with quote
Well I decided one day that the ultimate AE86 to own would be a TRDn2 car, as there doesnt appear to be alot of these floating about I figured I would have to build my own !
I have studied the TRD manual for some time and came to the idea that one of these should be easy to build , the only thing I was going to need was a huge pile of money! Stupid
I happen to have a good shell that looked like it needed a purpose in life so that is where I began.
After stripping the car and removing everything from inside, I started on yet another cage
As the car is having the N2 fenders there is a lot of work in cutting and reshaping the rear wheel arches to make all this happen, this is where the body shell is at the moment so when I take some more photos I will come back to the body shell
Back to top
nzae86
Wataru
PostPosted: Tue Jan 01, 2008 10:24 am    Post subject: Reply with quote
Probably the most difficult part of building one of these cars to the correct specs is the engine. I managed to find a engine from a formula Atlantic swift DB4 so there can be no doubt if this engine is "atlantic spec" or the real deal.
Stripping the engine down and starting from the begining is the only way to go .I bought new TRD pistons that I found had been sitting on a shelf with another set for over 10 years .The steel billet crank is shown in this picture along side a standard smallport , supercharged,20v, crank
The rods are TRD , and I bought another dry sump set up that is more suited to RWD ,it is a TRD sump with a Barnes pump
This is the bottom end mocked up to make sure everything fits
My engine builder was not happy with the size of the oil pump belt so the front pulley setup is in for a change, the atlantic cars never ran an altenator so all this needs a rethink
Back to top
nzae86
Wataru
PostPosted: Tue Jan 01, 2008 10:36 am    Post subject: Reply with quote
The early Atlantic engines used carbs so did the N2 cars so the head and carbs were stripped down crack tested, rebuilt and put back together again
The inlet and exhaust cams are both 320 deg with 10.6mm lift TRD #881
The Atlantic flywheel is to small to run a sedan type car so I had one made from high tensile billet, looks a bit like a steering wheel
The clutch is a twin plate Quartermaster 71/4 inch
Back to top
nzae86
Wataru
PostPosted: Tue Jan 01, 2008 10:42 am    Post subject: Reply with quote
Well after some time and careful design by my engine builder it is all together and waiting for me to finish the rest of the car
I hope it goes as well as it looks !!!
Back to top
nzae86
Wataru
PostPosted: Tue Jan 01, 2008 10:54 am    Post subject: Reply with quote
The good thing about building one of these cars is that alot of very expensive development had been done by TRD, so using the information that they had it is easy to find what these cars need to work .
these shocks have been taken from the N2 manual
I have fitted a coilover set up as TRD ran with a spring rate from the middle of the range to start with
And the finished strut with Tein strut tops
Some front caster rods will match well with the TRD front and rear swaybars
Back to top
nzae86
Wataru
PostPosted: Tue Jan 01, 2008 11:13 am    Post subject: Reply with quote
The gear kit is the same as what I use in my tarmac rally car but this one will be combined with a TRD 5.3 crown wheel and pinion and a TRD 2 way LSD
These cars also ran a diff pump and cooler so that is what this will have
As TRD do not make a gearbox mount any more I managed to get a cusco item and engine mounts
Back to top
Rick
Iketani
PostPosted: Tue Jan 01, 2008 11:15 am    Post subject: Reply with quote
Iam so jealous Worship Worship Worship
_________________
Corolla Levin SR 1984 AE-85 (Project car 1)
Corolla Levin SR 1987 AE-85 (Project car 2)
Sprinter Trueno BZ-G 1995 AE111 (Runabout)
Back to top
nzae86
Wataru
PostPosted: Tue Jan 01, 2008 11:27 am    Post subject: Reply with quote
What I thought was going to be one of the hardest thing to find for this project was one of the easiest and cheapest !
The wheels came on a Datsun 280Z that I bought just for the wheels , but I managed to sell the car for more than I paid with some steel wheels on it !
The fronts are 15 x 8.5 and the rears are 15 x 9 SSR
Back to top
nzae86
Wataru
PostPosted: Tue Jan 01, 2008 11:38 am    Post subject: Reply with quote
I will put all this in order as the project continues
Back to top
Erik_dk
Ryousuke
PostPosted: Tue Jan 01, 2008 12:26 pm    Post subject: Reply with quote
damm give me more. i want to see more:-) i want one also:-)
_________________
Corolla GT Twin Cam AE86 whit 4agze:-D SOLd:-(
Ke70 rocks:-D
Back to top
banpei
Site Admin
1982 Toyota Carina
PostPosted: Tue Jan 01, 2008 1:00 pm    Post subject: Reply with quote
More! More! More! Thumbsup
_________________
*** http://shop.aeu86.org - shop at aeu86 dot org - Sint Vitusstraat 78, 1211PK Hilversum, NL ***
Back to top
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger Skype Name
Eircamae86
Takumi
PostPosted: Tue Jan 01, 2008 1:05 pm    Post subject: Reply with quote
Fantastic build there mate, Serious Enthusiasm Keep us posted, this I want to see,
_________________
Back to top
jap-si
Iketani
PostPosted: Tue Jan 01, 2008 1:31 pm    Post subject: Reply with quote
fanstastic spec. can't wait to see it.
Back to top
katapouser
Itsuki
PostPosted: Tue Jan 01, 2008 4:20 pm    Post subject: wow Reply with quote
nice projekt you have going there.
have you bought the bodykit yet?, or are you going to make it your self,
_________________
why drive, when you can drift
Back to top
mouwt
Iketani
PostPosted: Tue Jan 01, 2008 9:07 pm    Post subject: Reply with quote
Wooaa...... That is unreal, Dream car for me right there
Back to top
View user's profile Send private message Send e-mail MSN Messenger
rwdlover
Iketani
PostPosted: Tue Jan 01, 2008 9:30 pm    Post subject: Reply with quote
looking good Thumbsup
_________________
Burn rubber and not your soul
Back to top
JonnyAE86
Takumi
PostPosted: Tue Jan 01, 2008 10:17 pm    Post subject: Reply with quote
This is pure porn! Thumbsup
_________________
Back to top
View user's profile Send private message Visit poster's website MSN Messenger
20vPETE
Ryousuke
PostPosted: Wed Jan 02, 2008 3:55 am    Post subject: Reply with quote
man u got deep pockets there,alot of money.well done
_________________
if first u dont succeed,ur not trying hard enough
Back to top
nzae86
Wataru
PostPosted: Sun Jan 06, 2008 10:23 am    Post subject: Reply with quote
These photos show the extent that the rear wheel arch needs to be removed to fit the N2 body kit , the outer is cut up and the inner wheel arch is then folded out and welded together , all this is as per TRD's instructions in the N2 manual
This allows for large wheel offset and being able to have the car set very low
The back floor has been reshaped to take the new fuel cell , which will be mounted more to the left (RHD car) to get a better balance to the car when full of fuel,
the area on the right hand side of the tank will house the fuel surge tank , pumps and filters , with also enough room to take the diff pump as well
Back to top
belchilov
Itsuki
PostPosted: Sun Jan 06, 2008 12:27 pm    Post subject: Reply with quote
dSmilebWorship Worship Worship Worship Thumbsup Thumbsup
_________________
Back to top
86er
Ryousuke
PostPosted: Mon Jan 07, 2008 1:59 am    Post subject: Reply with quote
i saw a bit of this on club4ag this is spectacular, cant wait too see finished build, but you need to get some watanbes just like trd n2 car Drool Drool Cool
_________________
"life begins at 8000rpms" - Blacktop 20v
Back to top
The Doctor
Bunta
PostPosted: Mon Jan 07, 2008 2:35 am    Post subject: Reply with quote
Worship Worship
Why are the camcovers so high on front, is there something underneath which needs that space?
_________________
Back to top
HybriD07
Takumi
1985 Toyota Corolla AE86 (late EU)
PostPosted: Mon Jan 07, 2008 3:39 am    Post subject: Reply with quote
Nice project can't wait to see and hear it when it's finished. How much power do you think the engine will make? This should be heading past the 200 mark right Blonde question
_________________
Back to top
XJS
Wataru
PostPosted: Wed Jan 09, 2008 12:20 pm    Post subject: Reply with quote
nzae86, you've mentioned TRD N2 manual several times. It's the same as TRD Levin Trueno Bible? If not, would it be possible to get a copy of it somehow?
Back to top
speed-inc
Takumi
PostPosted: Wed Jan 09, 2008 12:45 pm    Post subject: Reply with quote
Nice built.
Thumbsup
Can't wait to hear that. Drool
_________________
Speed Industries
Hurdnerwaeldlistr. 73
8808 Pfaeffikon
Switzerland
e-mail: info@speed-industries.ch
phone: +4155 420 15 69
page under construction
We have all the parts your Hachi needs
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Projects All times are GMT + 2 Hours
Page 1 of 4
Jump to:
You cannot attach files in this forum
