| Author |
Message |
ToyotaTs Iketani
| Back to top |
El_Camino Takumi
1983 Toyota Corolla AE86 (early Levin)
Posted: Fri Jun 02, 2006 7:41 pm Post subject: |
I guess you are using the same gearbox as 4AGE thatswhy the final gear ratio is a bit short to reach higher speeds.
You can easily check your top speed from this diagram:
_________________ "..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984
| Back to top |
Knudsen Moderator
Posted: Sat Jun 03, 2006 7:17 pm Post subject: |
El_Camino
Where do you have that diagram from?
I have measured my speed in the hachi, to 198km/h@7270rpm in 5. gear with gps and Apexi SAF-C.
_________________ Youtube Myspace and IŽll Google your Yahoo
| Back to top |
El_Camino Takumi
Posted: Tue Jun 06, 2006 10:50 am Post subject: |
Knudsen, this depends also from the tire diameter - I calculated it with my tires - 195/60/14. The final ratio is 4.1, and the gears as follows - 3,587, 2,022, 1,384, 1,000, 0,861
This is a japanese Excel file I have found I partly translated in English.
| Back to top |
