| Author |
Message |
ZaX Moderator
Joined: 20 Sep 2004 Posts: 1430 Location: Croatia / Zagreb
Posted: Thu Dec 09, 2004 4:19 pm Post subject: Injector sizes info |
I've found this information about 4a-ge injector sizes.
http://www.geocities.com/MotorCity/Pit/9975/dat...ct/Injectors.html
"How many injectors can one guy have? Well I found out pretty early that the standard 215cc/min Beige injectors (top right) weren't going to deliver enough fuel for the new cams. I tried the Supercharger 4AGZE 365cc/min Orange injectors (Bottom right) but they were just too big and was causing the ECU to go into limp home mode. Finally I got a set of 100kW Green 250cc/min injectors (Bottom left) and that did the trick. "
Source: http://www.geocities.com/MotorCity/Factory/8762/TRDcampics.htm
CC / MIN COLOR OHMS lbs / HR kPa APPLICATION
365 red/orange 2.9 33.9 255 4AGZE
210 blue 2.4 20.6 255 4AGE
200 pink 2.7 19.6 290 4AGE
182 dark grey 2.0 17.8 255 4AGE
250 green 13.8 24.5 290 4AGE
250 purple 13.8 24.5 290 4AGE
213 beige 13.8 20.9 290 4AGE
155 violet 13.8 15.2 290 4AFE
Source: http://www.toysport.com/webpages/Techinfo/References/injectors.htm
_________________
| Back to top |
robokill Bunta
Joined: 07 Sep 2004 Posts: 2197 Location: Amsterdam // The Netherlands
Posted: Thu Dec 09, 2004 6:39 pm Post subject: |
nice list needed this sooner i want 295 CC injectors with 272 duration cams ..
_________________ "08 Honda Civic Hybrid
KIS it
Keep It Sideways
| Back to top |
Ivan141 Moderator
Joined: 06 Sep 2004 Posts: 4819 Location: Netherlands Z-H
Posted: Thu Dec 09, 2004 9:32 pm Post subject: |
I think I have a set of those green injectors at home, are those from early ae92's with bluetop?
'81 poor guy with a money-pit
| Back to top |
KristianAE86 Moderator
Posted: Mon Dec 13, 2004 6:38 pm Post subject: |
| Ivan141 wrote: | | I think I have a set of those green injectors at home, are those from early ae92's with bluetop? |
if these are the genuine green 250cc injectors... Ivan man - just give me a price - NOW:
_________________ I´m sorry sir, your planet has been sceduled for destruction
| Back to top |
Ivan141 Moderator
Posted: Tue Dec 14, 2004 1:34 am Post subject: |
Sorry, just took a closer look, they are just slightly discoloured beige ones. Otherwise I would have used them myself..
| Back to top |
jamiemirror Bunta
Joined: 04 Jan 2005 Posts: 1795 Location: Sofia, Bulgaria
Posted: Wed Jan 05, 2005 2:18 pm Post subject: |
If you use adjustable FPR (fuel pressure regulator) - you can fine tune your injectors rate
http://www.avcweber.gr/malpasi/weber11.htm
I have RP12 from wrecked FORD engine - it cost me only ~15EU and fits to bigport 4AGE fuel rail !
| Back to top |
Ian.G Bunta
Joined: 15 Oct 2004 Posts: 751 Location: Derby UK - Land of road legal race cars
1985 Toyota Corolla AE86 (late JDM Levin)
Posted: Wed Jan 05, 2005 2:27 pm Post subject: |
I think I will be needing some bigger injectors too
Does anyone know if other cars use the same type injectors as the 4AGE ?
_________________ Regards Ian.
| Back to top |
jamiemirror Bunta
Posted: Wed Jan 05, 2005 2:30 pm Post subject: |
| Ian.G wrote: | I think I will be needing some bigger injectors too
Does anyone know if other cars use the same type injectors as the 4AGE ? |
If you go turbo - you may use 440 cc Supra Turbo 7MGTE injectors - they FIT to the rail, 2.6 ohms, are cheap at Ebay and are available.
| Back to top |
robokill Bunta
Posted: Sun Aug 31, 2008 12:37 am Post subject: |
MAKE IT A STICKY PLZ!
KIS it
Keep It Sideways
| Back to top |
tolisspi Takumi
Joined: 24 Jan 2008 Posts: 253 Location: Greece-Korinthos
Posted: Sun Aug 31, 2008 9:30 am Post subject: |
So which bigger injectors can we connect on the bigport wiring injector? I want to fit bigger injector without mods.
_________________ **COROLLA EE80 - 4AGE 124HP**
| Back to top |
mrgud Takumi
Posted: Sun Aug 31, 2008 10:54 am Post subject: |
| tolisspi wrote: | | So which bigger injectors can we connect on the bigport wiring injector? I want to fit bigger injector without mods. |
what do you mean?
You can try the ones from the 3sge (2,0 engine, celica), the same ones are on the 7mge Supra (mk3)... I hear they put them on the 7AGZE engines, 1,8 SC
_________________ SNO-MO-BIRU project started- CHIRO
| Back to top |
tolisspi Takumi
Posted: Sun Aug 31, 2008 2:44 pm Post subject: |
Im meaning that i want to find injector to connect with the oem plugs wiring. Also the the bigport's injectors are 1ohm
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Sun Aug 31, 2008 3:21 pm Post subject: |
| robokill wrote: | | MAKE IT A STICKY PLZ! |
Sticky or in the technical section on the front page?
| Back to top |
Project D Wataru
1987 Toyota Corolla AE86 (late EU)
Posted: Tue Sep 02, 2008 12:14 pm Post subject: |
| banpei wrote: | | robokill wrote: | | MAKE IT A STICKY PLZ! |
Sticky or in the technical section on the front page? |
_________________
| Back to top |
