Injector Impedence.
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
byd1380
Wataru
PostPosted: Tue Jul 24, 2007 1:01 am    Post subject: Injector Impedence. Reply with quote
I have fitted ITB's and standalone ECU (Perfectpower XMSL). I had the car running and drove it over to the rolling road to get mapped. That was two months ago!!! The car will not take any throttle, we have tried moving the crank position sensor, rewired the ECU/engine, but still no joy. I am convince the ECU cannot drive the injectors. According to the Toyota manual the injectors should measure 13.8 Ohms. Does this mean thay are high impedence, could I change them for low impedence ones?
Cheers
Ivan
_________________
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
Back to top
parrot
Takumi
PostPosted: Tue Jul 24, 2007 2:58 am    Post subject: Reply with quote
13.8 is high impedence. Low impedence is typically in the 1 - 3 ohm range. Put a multimeter across the two injector terminals and see what resistance they are. Check what resistance injectors your standalone ecu requires. Perhaps the ECU can be programmed to run whatever you want to run resistance wise?
The ECU and injector resistances have to tally or it won't run properly
Back to top
jamiemirror
Bunta
PostPosted: Tue Jul 24, 2007 9:49 am    Post subject: Reply with quote
Get ECU (Perfectpower XMSL) manufacturer's support about that.
Back to top
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger MSN Messenger
jondee86
Takumi
PostPosted: Tue Jul 24, 2007 10:25 am    Post subject: Choking ?? Reply with quote
Is the engine running when you say "will not take any throttle" ?
Does this mean that it chokes and dies when you open the throttle ? If
so, it is often a sign that the timing is over-advanced.
Cheers... jondee86
_________________
Back to top
byd1380
Wataru
PostPosted: Wed Jul 25, 2007 4:18 pm    Post subject: Reply with quote
I have been in contatc with Perfectpower directly, they said I would nee to run a set of amplifiers to run the injectors of that impedence. I have got them now, so will hopefully get the car sorted soon.
Will keep you posted on the power output etc.
Cheers
Ivan
_________________
Back to top
jamiemirror
Bunta
PostPosted: Wed Jul 25, 2007 4:28 pm    Post subject: Reply with quote
Something like that ?
http://www.jbperf.com/p&h_board/
Back to top
byd1380
Wataru
PostPosted: Mon Jul 30, 2007 6:08 pm    Post subject: injector impendence Reply with quote
I went up to the car today and the guy had the injector Amplifiers wired in, this seems to have cured the problem, can runs quite well. His rolling road is broken at the minute so once that is sorted the car can get properly mapped. Then just need to tidy it up.
Will post power figures when it' done.
Cheers
Ivan
_________________
Back to top
tolisspi
Takumi
PostPosted: Fri Aug 29, 2008 1:37 pm    Post subject: Reply with quote
Which injectors(up to the OEM) can we use for 4age bigport wiring plug/connector injectors? I dont want to replace the wiring connector of bigport.
Thx a lot
_________________
**COROLLA EE80 - 4AGE 124HP**
Back to top
Chrisso
Iketani
PostPosted: Mon Sep 01, 2008 6:07 am    Post subject: Reply with quote
use any bigport or smallport injectors I think the plugs are the same. I thought they were all low impedence (just check with a multimeter) and top feed. Later 20v injectors are high imp. and side feed. If you need more flow, 7mge injectors fit and flow ~295cc, and 7mgte injectors flow more again.
Back to top
parrot
Takumi
PostPosted: Mon Sep 01, 2008 1:30 pm    Post subject: Reply with quote
No, there are different plugs for different injectors.
See here http://www.geocities.com/MotorCity/Pit/9975/dataBySubject/Injectors.html
I also believe that you need the correct impedence for your ECU (high or low) but have heard of a couple of people who claim they put high impedence smallport greens into a bigport low impedence ECU controlled engine.
Back to top
Chrisso
Iketani
PostPosted: Tue Sep 02, 2008 9:44 am    Post subject: Reply with quote
Thanks for the correction parrot. Actually, I should have know that because I have seen that page before! With regards to the correct impedence for the ECU you should be able to adjust this with resistors. However, I'm not an electrical kinda person so please get a second opinion on this!
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
