Fuel sender unit
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
vpmurdoch
PostPosted: Tue Sep 02, 2008 3:48 am    Post subject: Fuel sender unit Reply with quote
Hi All,
I have a broken fuel sender unit and am looking at replacing it with a generic brand. Can anyone tell me what the resistance of the full and empty levels should from the sender?
Thanks,
Vernon.
Back to top
Chrisso
Iketani
PostPosted: Tue Sep 02, 2008 9:42 am    Post subject: Reply with quote
You can slide a multimeter across the coil in the sender unit to determine the resistance, unless of course you've broken the coil, in which case, WTF?!!
Have a look on www.autoshop101.com One of the tech docs may have that data
Back to top
vpmurdoch
PostPosted: Tue Sep 02, 2008 11:32 pm    Post subject: Reply with quote
The unit is completely stuffed, otherwise I would have done as you suggested. I tried cleaning and inspecting the wires, as you say the coil must be broken. Thanks for the link, I will check it out and see if it can tell me what it need.
BTW: It is an AE101 jap import (4age silvertop), if anyone else has the data handy.
Cheers,
Vernon.
Back to top
F0Bman
Takumi
PostPosted: Wed Sep 03, 2008 5:33 am    Post subject: Reply with quote
The fuel sender unit can be cleaned if the contacts are dirty with lots of build up.
_________________
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
Back to top
Chrisso
Iketani
PostPosted: Wed Sep 03, 2008 7:15 am    Post subject: Reply with quote
Have you physically inspected the coil? I'm not saying it's impossible, but I find it very hard to believe that the coil has separated! You should be able to open the unit up so that the coil and contacts are exposed.
When I bought my sprinter I had to bend the slider on the top of the float arm so that it made solid contact with the coil, and the fuel gauge has now been working for 6years.
Back to top
vpmurdoch
PostPosted: Wed Sep 03, 2008 7:41 am    Post subject: Reply with quote
Had it in bits, looks like someone else has had their hands in it and not been careful. Or taken to it with the wrong tools. Off to the wreckers this weekend for a replacement I would say. Smile
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
