Fuel pump and starter on the same relay
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
Max_toy
Wataru
PostPosted: Tue Aug 19, 2008 9:23 am    Post subject: Fuel pump and starter on the same relay Reply with quote
hi
can i connect the fuel Pump and starter to one 5 pin relay switch
85 ground
86 ignition
87 battery
30 fuel pump and starter
Viewed 37 Time(s)
AE86 : Technical > Fuel pump and starter on the same relay
Back to top
jondee86
Takumi
PostPosted: Tue Aug 19, 2008 11:09 am    Post subject: Reply with quote
If the "starter" wire energises the starter solenoid, it won't work.
If the "starter" wire leads to a second set of contacts that close to
energise the starter solenoid, then yes, it will work Smile For example.
the second set of contacts could be a momentary contact "start"
push button, or the "start" contacts on the ignition keyswitch.
Cheers... jondee86
Back to top
View user's profile Send private message Send e-mail
F0Bman
Takumi
PostPosted: Wed Sep 03, 2008 5:40 am    Post subject: Reply with quote
The starter and fuel are not on the same relay, but on seperate circuits turned on in unison.
_________________
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
Back to top
Chrisso
Iketani
PostPosted: Wed Sep 03, 2008 7:10 am    Post subject: Reply with quote
Search for parrots post with links to the Electrical Wiring Diagrams. Everyone who even looks sideways at their wiring should have one of these open next to them!
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
