| Author |
Message |
firehawk Takumi
Joined: 10 Jun 2005 Posts: 240 Location: Turku, Finland
Posted: Sun Nov 20, 2005 12:37 am Post subject: Firehawk's N2 racecar project |
Phew, after about 1200 kilometers of driving and a total of 16 hours on a ferry, I'm finally a happy owner of a 1986 AE86 Levin 3-door. Thanks to Widar for letting me buy one of his hachirokus - I promise to take really, really good care of it!
Here's a few photos I took after we had finished loading the car onto the trailer, and one I took on the ferry's car deck;
http://paranoia.tuug.fi/gallery2/v/jh/ae86/nov19/
Anyway, the plan is to begin by reconditioning the bodywork, which should be started off by stripping all parts off the car, leaving a bare bodyshell. Getting all the soundproofing, underbody sealant and rusty bits off the car should provide me some entertainment for a while, after which it's time to replace the rear arches, patch any rust holes found and generally reinforce the body a bit by spot welding. Finally, I'll try to finish the exterior repairs by lead soldering to minimize the need for polyester body filler. Then - it's time for a few coats of primer and some 040 Super White II.
I haven't yet decided on what to do after the body is finished, but the engine is probably the next in line. I have to decide on whether I should rebuild the current bluetop 4A-GE or go for a low-mileage japanese-import redtop. I'm quite certain that both 20v engines are illegal to swap into an AE86 in Finland so those are unfortunately out of the question as I want the car to stay street-legal.
Yes, and as those sandblasted and powdercoated bits you guys have been flashing off here on the forum looked really impressive, I may have to jump on the bandwagon.
_________________ Jani Halme / Red 5 Racing || AE86 / EP3 / SW20 / ED9
| Back to top |
Widar Bunta
Joined: 07 Sep 2004 Posts: 1820 Location: Borås, Sweden
Posted: Sun Nov 20, 2005 1:39 am Post subject: Re: Jani's Levin -project |
| firehawk wrote: | Thanks to Widar for letting me buy one of his hachirokus - I promise to take really, really good care of it!  | You are way to kind!
Off course i wanted to sell it to someone that's gonna take good care of it!
Jani (Firehawk) also brought the AE86-movies i was missing like Best Motoring 41 AE86 special... He's a great guy!
Wishing you all the best, and as i said, if you encounter any problems with the car, don't hesitate to call!
/Widar
_________________
| Back to top |
nmwisima Bunta
Joined: 23 Dec 2004 Posts: 3613 Location: Athens Greece
1996 Mazda MX-5
Posted: Sun Nov 20, 2005 2:55 am Post subject: |
Well Jani, VERY nice!
One more happy owner
I am sure you re gonna take care of her
Shame the 20V isn't legal... Here neither. But here you can go pay and register it! Cant you do that in Finland?
Of course here, why bother register? You 'll just have to pay something to the MOT guy
There is something LEGAL though: Only the first 4 numbers of the engine VIN are checked, so... 4ageuc... 4agzeuc... No difference here
Why dont you check this out?
_________________
| Back to top |
James Takumi
Posted: Sun Nov 20, 2005 8:54 am Post subject: |
Ahh Widar you did sell it in the end...well it's good to see it going to a good home.
_________________ Triumphs without difficulties are empty. Indeed, it is difficulties that make the triumph. It is no feat to travel the smooth road
* 1984 AE85 Toyota Trueno, 3AU 1500cc (getting panel and painted)
* 1992 R32 GTS-t Skyline, RB20DET (the mrs' daily driver but I own it, strange how that works)
* 1995 Honda Accord, 2.2Ltr VTEC (My daily driver)
| Back to top |
SuperHessu Iketani
Posted: Sun Nov 20, 2005 10:32 am Post subject: |
You lucky bastard, I made an offer of that car one day too late...
I bet you can register a hachi roku with 20valve blacktop in Finland, or at least I attend to... And a turbo engine is even easier, as you can take a dyno-paper of the car with less than the +20% allows, just lower the boost enough...
_________________ Totally rebuilding an AE86...
www.fintoys.net
www.findori.net
www.koti.mbnet.fi/teemu-t
| Back to top |
firehawk Takumi
Posted: Sun Nov 20, 2005 12:02 pm Post subject: |
Well, on paper the 20v engines make too much power (only 20% increase is allowed, stock is 124hp so up to 149hp is allowed) to be legal in an AE86, but one thought I had was telling them that only the head is from a 20v but the block+bottom end is stock - I'll be damned if any of the MOT guys can tell the difference between 3-rib and 7-rib blocks. This makes the engine a "home-made" one, and the power on paper is no longer valid and needs to be established with a dyno plot. Then just use an e-Manage or something to retard the ignition a bit at the top and set a rev-limiter to, say, 7200rpm and suddenly a blacktop makes a bit less power for the dyno run. Disabling the VVT-i for the dyno run might also do the trick.
If only the 20v cam covers looked the same as 16v - there wouldn't be any need to actually register the new engine..
| Back to top |
Darkstar Ryousuke
Joined: 20 Jan 2005 Posts: 140 Location: Warsaw, Poland
Posted: Sun Nov 20, 2005 12:38 pm Post subject: |
It seems that this car is a great base for a project - that's why I sent an offer to Widar some time ago (thanks for you patience, and sorry for the whole trouble I made). As a result, the Hachi went to Finland instead of Poland and I'm searching for another car.
It's a shame you need to do all these tricks to make the car roadlegal in FIN - here in Poland you only have to get a paper from the place that measures everything, like smog compliance, sound level, light alignment etc. (can't even call it MOT) and you're read legal! Fortunately there's no power limit, simply because there are no dynos in the whole country, except for those in tuning shops.
_________________ Ahhh, VTEC. All the lag, none of the turbo. It's like waiting for bad sex.
| Back to top |
Widar Bunta
Posted: Sun Nov 20, 2005 12:42 pm Post subject: |
Wonder how long you can use a car on Polish plates here in sweden....
_________________
| Back to top |
SuperHessu Iketani
Posted: Sun Nov 20, 2005 1:23 pm Post subject: |
That was my point exactly, to lower the power enough to make it legal, but in a turbo engine it's a bit easier to do that, and in the 20 valve they might start to arque that the engine has had more power coming out of stock than it currently has.... But then again, there is a hachi in Finland having a 4A-GZE turbo converion, and made street-legal by taking a dyno paper at 0.3bar boost, as in real life, it's driven with 2.2bar...
And I have also thought of removing all text from the head covers, that way no one will know that it's a 20 valve, but then they might notest that the block number is different from the original, and request a dyno-run... It's a bit kinky, but with some imagination, everything is possible....
www.fintoys.net
www.findori.net
| Back to top |
Apolan Bunta
Joined: 27 Nov 2004 Posts: 1851 Location: Slovenia, Ljubljana
Posted: Sun Nov 20, 2005 1:41 pm Post subject: |
| firehawk wrote: | Well, on paper the 20v engines make too much power (only 20% increase is allowed, stock is 124hp so up to 149hp is allowed) to be legal in an AE86, but one thought I had was telling them that only the head is from a 20v but the block+bottom end is stock - I'll be damned if any of the MOT guys can tell the difference between 3-rib and 7-rib blocks. This makes the engine a "home-made" one, and the power on paper is no longer valid and needs to be established with a dyno plot. Then just use an e-Manage or something to retard the ignition a bit at the top and set a rev-limiter to, say, 7200rpm and suddenly a blacktop makes a bit less power for the dyno run. Disabling the VVT-i for the dyno run might also do the trick.
If only the 20v cam covers looked the same as 16v - there wouldn't be any need to actually register the new engine..  |
i cant believe you have to go through that much trouble to get something like 20v registred legally. if i drove my hachi to mot w/ a 20v inside.. heh, hez never even seen a 4ag before, letalone the blacktop. here they dont even check the engine number.. its all up to the judgement of the MOT-guy. somebody here even passed MOT w( a BMW e30 318i (and had m50 2.5 w/ near 200 hp. but in that case the "blue envelope" happened. =) here you can have anything under the hood, as long as it looks fairly stock. (but if you paint the cam covers red or something like that they wont let you through. and you might get a fine for having a flashy "tuning" object on your car) stupid law.
_________________ There are no good decisions or bad decisions - only deciding or running away.
-me, 2007
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Sun Nov 20, 2005 2:27 pm Post subject: |
Good luck with the project!
| Back to top |
Darkstar Ryousuke
Posted: Sun Nov 20, 2005 3:42 pm Post subject: |
Widar, don't tell me there's a power limit in Sweden, like in Finland...
SuperHessu, damn, what kind of turbo does you friend run?! 2.2bar?!
I think that we Polish guys are fortunate - a month ago the government introduced a new law that allows you to change engines freely, even without going to this MOT office, and you don't even have to change the numbers in your car's papers - that's because there's no place to put the engine number in!
| Back to top |
SuperHessu Iketani
Posted: Sun Nov 20, 2005 5:18 pm Post subject: |
He's not a friend of mine, I've just read of his project in fintoys-forum, as I'm sure Jani has too... Don't remember/know his current turbo, but at some point he had a track-racing-truck turbo, don't remember if he ever installed it...
Jani, if all goes well, we'll have a race next summer on a fintoys-track-day..?
www.fintoys.net
www.findori.net
| Back to top |
Mr Doricar Wataru
Posted: Sun Nov 20, 2005 5:33 pm Post subject: |
Why didn't you drive it home
Good luck with it dude. Looks like a solid project!
| Back to top |
Darkstar Ryousuke
Posted: Sun Nov 20, 2005 9:45 pm Post subject: |
SuperHessu, do you know if that turbo was a Holset? From what I know, it's quite popular in Scandinavia to use them in these crazy BMW turbo conversions, as they're available at a lower price than most of the well-known turbo brands.
| Back to top |
SekiguchiUeno Takumi
Joined: 25 Feb 2005 Posts: 479 Location: Czechoslovakia/Germany
Posted: Sun Nov 20, 2005 11:06 pm Post subject: |
its possible in poland to get papers for an 20old car without problems
_________________ All the hachies that Daytona can only dream about
| Back to top |
firehawk Takumi
Posted: Sun Nov 20, 2005 11:11 pm Post subject: |
The guy actually lives in the same city as I do and I see his car occasionally in summertime (it's the other of the two coupés here - the other one being Ni-Go's). I think he's running a Holset HX40 turbo on it but I'm not absolutely sure - the rumor has it that the car made 426bhp when he dynoed it last year. Quite understandably, he doesn't really boast around with the dynoed power figures, given that the car is registered for 149bhp or less. Here's a photo of the engine bay, found on RMF's website.
Anyway, since Finland is apparently a heaven for bureaucrats, we have all these stupid laws which are pretty much made just to annoy us car enthusiasts. Still, from what I've heard, we're still better off than, say, californians.
Mr. Doricar - haha, I wonder what the law enforcement would've thought of seeing me driving it through Sweden.
Superhessu - sure thing, given that I have the car up and running by that time. I'll do my best, though! I think, by the way, that the 20v block just says "4A" just like the 16v ones - the serial number is of course different but I'm not sure whether it's mentioned at all on the registration papers? Also, at least on a silvertop, just removing the center panel covering the spark plugs makes it look somewhat similar to a 16v. The throttle bodies may require a bit of explaining but adding them to a "16v" is not illegal.
| Back to top |
firehawk Takumi
Posted: Tue Nov 22, 2005 11:37 am Post subject: |
Well, I went to the garage yesterday just take a small peek under the carpets but ended up stripping most of the interior and chipping off about half of the sound deadening material on the floor. Found a bunch of rust spots already patched but no rust holes anywhere - for a 318000km car the body is surprisingly good! The corners underneath the rear bumper look a bit dubious but it seems to be all metal despite the fair amount of putty on top of it.
I've added some photos to my image gallery;
http://paranoia.tuug.fi/gallery2/v/jh/ae86/nov22/
Here's a photo of the current state of the interior;
| Back to top |
Widar Bunta
Posted: Tue Nov 22, 2005 12:01 pm Post subject: |
Keep up the good work, Jani!
_________________
| Back to top |
Darkstar Ryousuke
Posted: Tue Nov 22, 2005 6:01 pm Post subject: |
| firehawk wrote: | | I think he's running a Holset HX40 turbo on it but I'm not absolutely sure - the rumor has it that the car made 426bhp when he dynoed it last year. |
Holy crap, that's some serious power!
The car really does look good considering the odometer state. We-want-more, we-want-more!
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Tue Nov 22, 2005 8:47 pm Post subject: |
You're quick. Only three days in Finland and already busy on the car.
| Back to top |
Yonzie Ryousuke
Joined: 17 Sep 2004 Posts: 163 Location: Copenhagen, Denmark
Posted: Wed Nov 23, 2005 5:13 pm Post subject: |
| firehawk wrote: | Well, on paper the 20v engines make too much power (only 20% increase is allowed, stock is 124hp so up to 149hp is allowed) to be legal in an AE86, but one thought I had was telling them that only the head is from a 20v but the block+bottom end is stock - I'll be damned if any of the MOT guys can tell the difference between 3-rib and 7-rib blocks. This makes the engine a "home-made" one, and the power on paper is no longer valid and needs to be established with a dyno plot. | It's the same here in Denmark... With the added twist that you actually have to PROVE that the car still conforms to the emission specs it was born with... And it's not good enough putting it on a rolling road with a tester up it's exhaust. Apparently it's a 10k€ test, or ~3-4k€ if done in Sweden or Germany (Not including travel, etc.)...
Consider yourselves lucky.
_________________ Peugeot 206 1.6 XT - 09/2003
Toyota Corolla GT Coupé - 09/1984
Yonzie - 09/1980
| Back to top |
firehawk Takumi
Posted: Fri Nov 25, 2005 9:55 am Post subject: |
| banpei wrote: | You're quick. Only three days in Finland and already busy on the car.  |
Hehe - I believe that by the end of this coming weekend, I'll have the interior and engine bay stripped completely bare, leaving only a body on wheels.
Anyway, yesterday I started taking the engine apart in place since our engine lift is being borrowed and I'm too impatient to wait for him to return it. After taking off the alternator and intake manifold, I noticed that the block has 7 ribs! The head is, of course, a bigport one so I'm a bit confused on what kind of an engine this actually is. The way I see it, there are three alternatives;
- If the entire bottom end is from a zenki AE92, it should have 9.4 CR pistons with 20mm gudgeon pins and a crankshaft with 42mm big ends.
- It could also just have the 7-rib block and standard AE86 crankshaft with 40mm big ends and 9.4 CR pistons w/ 18mm gudgeon pins.
- Finally, it could be a full kouki AE92 bottom end, using 10.3 CR pistons w/ 20mm gudgeon pins and a crank with 42mm big ends.
Well, I guess I'll see which of those is true once I get the engine pulled off the car.
| Back to top |
banpei
