| Author |
Message |
totta Crolla Takumi
Posted: Sun Jan 06, 2008 10:36 pm Post subject: Final drive |
Wanted: lower final drive (cwp) 4.7-5.3
Where can you buy these at a reasonable price in the U.K ?
_________________ "accidents are rare but you're a long time dead"
| Back to top |
alimonos Bunta
Joined: 10 Jan 2005 Posts: 2527 Location: HPEIROS - GREECE
Posted: Sun Jan 06, 2008 11:41 pm Post subject: |
try here in AEU86 shop !!!
_________________ AE86 FANATIC!!!
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Mon Jan 07, 2008 10:01 am Post subject: |
Quick lookup in our pricelist says the 4.7 costs 500 euros and the 5.3 (trd) costs 1400 euros.
| Back to top |
Mux213 Site Admin
Posted: Mon Jan 07, 2008 10:41 am Post subject: |
And we have 4.7 in stock.
_________________ Greetz,
No more hachi
| Back to top |
totta Crolla Takumi
Posted: Mon Jan 07, 2008 12:15 pm Post subject: |
| alimonos wrote: | | try here in AEU86 shop !!! |
| Back to top |
totta Crolla Takumi
Posted: Mon Jan 07, 2008 12:43 pm Post subject: |
Before I logged on this morning I called Fensport about this, the chap on the 'phone seemed fairly un-interested saying "the cars getting quite old now, can't get parts anymore" that was it !!
Although they list a TRD CWP
I could'nt find any details in the AE86 shop, can someone let me know what ratio's are available and at what cost, thanks
| Back to top |
speed-inc Takumi
Posted: Mon Jan 07, 2008 12:49 pm Post subject: |
Sidenote:
Can you guys still supply the TRD 5.3?
I heard it is discontinued from TRD Japan?
Maybe from TRD US?
Just out of interest.
_________________ Speed Industries
Hurdnerwaeldlistr. 73
8808 Pfaeffikon
Switzerland
e-mail: info@speed-industries.ch
phone: +4155 420 15 69
page under construction
We have all the parts your Hachi needs
| Back to top |
Mux213 Site Admin
Posted: Mon Jan 07, 2008 1:49 pm Post subject: |
Totta,
We don't list the CWPs on the shop page because we don't stock them yet, not enough demand for them. We're still pretty a small shop you know We just happen to have the 4.7 in stock which we advertise in the commercial sales section. I would have to check for the availability of other types when I get back home tonight and can check with my supplier.
Speed-inc,
No idea really. We have it on our list of items we can order but that doesn't mean they still have it as the list is a little older. We generally get our thing through TRD HK if I am not mistaken.
No more hachi
| Back to top |
totta Crolla Takumi
Posted: Mon Jan 07, 2008 3:05 pm Post subject: |
| Mux213 wrote: | Totta,
Speed-inc,
No idea really. We have it on our list of items we can order but that doesn't mean they still have it as the list is a little older. We generally get our thing through TRD HK if I am not mistaken. |
Thanks for your help Mux, could get quite expensive but I consider this mod to be one of the best as my car is fairly standard power wise. I have a close ratio gearbox ready to go in when the cwp is done. What do you think ?
| Back to top |
Mux213 Site Admin
Posted: Mon Jan 07, 2008 3:51 pm Post subject: |
So far I've heard good things about the 4.7 ratio. I want to get one for my own car one of these days myself but need to save up for another LSD awell first.
Depends a bit on what you want to do with you car aswell offcourse.
The installation is one of the things thats holding me back aswell. Its hard to find a good place with a mechanic that does a proper job on these things.
No more hachi
| Back to top |
totta Crolla Takumi
| Back to top |
raki Iketani
Posted: Mon Jan 07, 2008 5:34 pm Post subject: |
Hi,
if you use a close ratio gearbox, you should take the 5.3, otherwise the 1. gear might be too long. That´s of course the perfect solution! With the 5.3 and the original gearbox the 1. gear might be a bit short.
I use a 4.7 with original gearbox and it´s a cheap medium, but okay...
BG
raki
_________________ www.sg-rallyesport.de
| Back to top |
totta Crolla Takumi
Posted: Mon Jan 07, 2008 6:07 pm Post subject: |
Yes I tried the CR box with a standard final drive, not too bad but the whole driving experience was kind of 'flat', I think it was too tall gearing in every gear except 5th
You could smell the clutch burning just by driving onto a trailer ! 5.3 is possibly the answer, oh, and the TRD clutch I have waiting to fit !
| Back to top |
nzae86 Wataru
Joined: 13 Dec 2007 Posts: 55 Location: Hamilton New Zealand
Posted: Mon Jan 07, 2008 8:59 pm Post subject: |
Hi there
I thought I'd share my experience with the different cw&p and gear box ratios in my Tarmac rally car
http://www.aeu86.org/viewtopic/nzae86s---ae86-l...-project-1/t/6170
When I first built my car that I destroyed I ran a standard ratio gear box with a 4.55 cw&p (the standard cw & p is 4.3)and this was a good start as it helped the car get of the line well and also closed up some of the gaps in the standard gear box ratios and 5th gear was a little more useable.
I then fitted a TRD close ratio box (the one with 2.3 first and lower 5th)and found that 1st gear was too tall, so I then purchased a 4.77 cw & p and this is the setup that I run now.
I feel that adding the c/r gearbox has been the best modification that I have ever made to my car, ideally I think that a 5.1 would be the best but TRD no longer make them.This car makes most of it's power from 3500 -7500 rpm so has alot of torque and has a wheel size of 205/50/15 and has a redline at 8500, max speed is about 210-215kph.There are a few other ae86's here that use a 5.3 cw&p and any rally or club events my car has been faster overall by alot.
Remember that this is on low profile Tarmac tyres , Gravel tyres are normally taller in their profile and this will have an effect on your gearing as well. Starts from the line take a while to get right, you just have to take off like a normal road start and then make the most of the long first gear, and from then on it just gets better and better.When I have raced this car at the curcuit in a grid start the other cars beat me off the line but while they are changing into 2nd gear ,my car passes them while still winding out in 1st and from then on it's all on !
My track car that I am building
http://www.aeu86.org/viewtopic/nzae86s-trdn2-ra...--project-/t/6171
I have just bought a 5.3 and same TRD gear kit as my rally car but this engine will have very little torque with a very narrow power band and a rev limit of 10500rpm ,so is going to need a shorter first gear to get moving and have the revs to still gain the top speed, this set up should suit most circuits here.
The gear kit here in NZ cost me about $2700NZD and the 5.3 $1500 NZD and a new 4.7 is about $750 NZD and are still available, I also just purchased 2 TRD lsd units as I was told that there will be no more made of the smaller axle size from TRD anymore, not sure how true this is but there were only 4 in the country here, but now I have some spares.
Hope this is of some help
| Back to top |
totta Crolla Takumi
Posted: Mon Jan 07, 2008 10:43 pm Post subject: |
Fine looking AE there nzae86, I would love to hear it running.
I'm using a Quaife Ford type 9 gearbox and 1st gear is currently good for about 40mph, similar I guess to the TRD one you have. My engine however is a fairly standard bluetop.
It should be possible to get a 4.77 ratio here in the U.K, anyone know what else is available ?
| Back to top |
raki Iketani
Posted: Tue Jan 08, 2008 12:05 am Post subject: |
@nzae86: Lucky guy! The gear kit in germany would cost about 3 times more than you paid... Maybe it would be a good idea to import it...
@totta Crolla: Your Toyota dealer should be able to order the 4.77... But why not order it from another country? I bought my r+p in the USA and it was including shipping and taxes, etc.. 150% cheaper as in Germany...
BR
raki
| Back to top |
filh Takumi
Joined: 10 Oct 2004 Posts: 244 Location: Liège Belgique
Posted: Tue Jan 08, 2008 3:05 am Post subject: |
I used both 4,7(Stageoneimports) and 5,3(Trd) ratio in rallies .From my experience , with a stock gearbox and 15" rims , the 5,3 is much more interesting , give you much response , and not too long ratio on 5th gear. BUT , it's quite expensive(paid 1450€ here in Belgium) , and have a very poor reliability (for cometition use)
Mine broke after 10 races. Easy to understand , as the same amount of power is distributed on less teeth.
I than bought the4,7 (300€ including delivery , with some parts , like washer , nuts , dust cover, bellville washer etc )
It's on for the third year now, without any noise ...LOnger ratio, but great reliability.
Hope it helps
Filh
_________________ Filh
Save the RWD cars
| Back to top |
matt mead Ryousuke
Joined: 01 Jun 2006 Posts: 156 Location: Sydney, AUSTRALIA
1984 Toyota Corolla AE86 (early JDM Levin)
Posted: Tue Jan 08, 2008 3:07 am Post subject: |
i ordered a 4.7 through this place http://www.greenline.jp/
cost me around $440 Aussie dollers... pretty cheap i thought..
im yet to test my 4.7 but im hoping it will make an imporvement on my standard t50 gearbox car... i think 5.3 would be alittle to much.. 5.1 sounds perfect but no longer can get it
| Back to top |
nzae86 Wataru
Posted: Tue Jan 08, 2008 3:58 am Post subject: |
| Quote: | I used both 4,7(Stageoneimports) and 5,3(Trd) ratio in rallies .From my experience , with a stock gearbox and 15" rims , the 5,3 is much more interesting , give you much response , and not too long ratio on 5th gear. BUT , it's quite expensive(paid 1450€ here in Belgium) , and have a very poor reliability (for cometition use)
Mine broke after 10 races. Easy to understand , as the same amount of power is distributed on less teeth |
That is why the N2 cars run a diff pump and cooler that returns the oil directly onto the pinion as being very small in diameter the stress on it is huge
| Back to top |
SYM Ryousuke
Joined: 24 Apr 2006 Posts: 179 Location: California, USA
Posted: Tue Jan 08, 2008 5:40 am Post subject: |
i have a brand new TRD 5.1 ring and pinion in stock, (yes the one that discontinued for yearrrsss)
and TRD 5.3 is already discontinued from Japan
email me if any one interested sym@passracing.com
_________________ P.A.S.S Racing
148 S.8th Ave, Unit-F
(626)961-6284
City of Industry
SYM@passracing.com
www.passracing.com
| Back to top |
filh Takumi
Posted: Wed Jan 09, 2008 12:06 am Post subject: |
Thanks NZAE86, a very interesting information. Never saw that on an ae86, but worth to be fixed on .
Was it made from TRD ? Not really to hard to realise , but I'm still convinced that the less teeth you have the less reliable it will be .
And When I broke my 5,3 , I was running with stock engine and gearbox , and with 15" rims
Filh
Save the RWD cars
| Back to top |
Ivan141 Moderator
Joined: 06 Sep 2004 Posts: 4819 Location: Netherlands Z-H
Posted: Wed Jan 09, 2008 7:41 pm Post subject: |
That diff cooling setup is a copy from the trd-bible for ae86. So yes, this was trd's solution to keeping the diff alive..looks like a good one too. I'd go one step further and weld a bulge in the diff housing as well for some extra oil capacity.
'81 poor guy with a money-pit
| Back to top |
TE71corolla Bunta
Joined: 20 Jan 2005 Posts: 807 Location: nederland/purmerend
Posted: Wed Jan 09, 2008 8:22 pm Post subject: |
i have this diffcooler setup in my ae86 racer
exactly the same,never broke a diff in this car(i broke an axle 2 times )
_________________
| Back to top |
nzae86 Wataru
Posted: Wed Jan 09, 2008 10:16 pm Post subject: |
This setup is from the TRD manual that covers Group A and N2 builds and was produced back in August 1985 by TRD , I also have the Levin and Trueno bible and it is more of a list of parts that were available
I have this manual in paper form and it would take a bit of time to scan it , I think I may finish building my car first !
| Back to top |
totta Crolla Takumi
Posted: Wed Jan 09, 2008 11:44 pm Post subject: |
| matt mead wrote: | i ordered a 4.7 through this place http://www.greenline.jp/
Great link this
| Back to top |
